shinden33
Posted: Tue Nov 13, 2007 10:01 pm Post subject: Yak'in Cross Country |
All,
I am (finally) planning on flying my -52 cross country from Rosamond, CA
(L00) to Collegeville, PA (N10). Planned Departure is on 26 November
hopefully arriving in PA sometime the following weekend. My current
proposed course is taking the southern route through AZ, NM, TX, OK then
turning north towards Louisville, KY and finally through Ohio into PA. If
anyone has any pointers on taking a stock Yak (that's right - no extra fuel)
I'm all ears. If you see a desert camo -52 in your neighborhood the week
after Thanksgiving stop over and say hi!
Scott
cjpilot710(at)aol.com Guest
Posted: Wed Nov 14, 2007 2:31 am Post subject: Yak'in Cross Country |
Scott,
Two good free internet web sites to use are Skyvectors.com and Airnav.com
Airnav is good for route planning. Very easy to use just make sure you ask it use only the airports it has received fuel reports with-in the last 30 days. A lot of airports these days are reporting their fuel prices to Airnav on a regular bases. It will give up to 10 routes than you can take you pick.
Skyvectors is great for en-route. Before takeoff you can check weather, bearing and distance, that is presented over a sectional chart display. Simples are presented over weather reporting station and the detailed report with a forecast at some station, will show up when you run the cursor over them.
One that requires a subscription ($25./yr) that is very good for detailed planning (best altitudes for wind, weather, icing, etc ) is weathermiester.com. Might be over kill for the Yak but it is an excellent preflight planner.
I use all the above regularly- even for short little flights (skyvectors).
Get your self a good seat cushion between you and the chute. Take water and a candy bar and stop and smell the roses now and than. Don't push it!
You're going to have a ball!
Jim "Pappy" Goolsby
In a message dated 11/14/2007 1:02:56 A.M. Eastern Standard Time, shinden33(at)earthlink.net writes:
| Quote: | --> Yak-List message posted by: "Shinden33" <shinden33(at)earthlink.net>
All,
after Thanksgiving stop over and say sp; (And Get Some AWESOME FREE find you for -Matt Dralle, List es y --> - MATRONICS WEB FORUMS ======================
Posted: Wed Nov 14, 2007 2:38 am Post subject: Yak'in Cross Country |
PS. Make sure you GPS data base is up to date and take two.
In a message dated 11/14/2007 5:32:29 A.M. Eastern Standard Time, cjpilot710(at)aol.com writes:
| Quote: | Scott,
Jim "Pappy" Goolsby
All,
://www.matronics.com/contribution">http://www.matronics.com/contribution
="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
.matronics.com/">http://forums.matronics.com
dsavarese(at)elmore.rr.co Guest
Posted: Wed Nov 14, 2007 4:45 am Post subject: Yak'in Cross Country |
Scott,
When you get settled in PA, contact me off list and if you're interested, we
can discuss the new fuel bladders for the 52.
Dennis
A. Dennis Savarese
334-285-2141
334-546-8182 (cell)
Skype: yakworld1
www.yak-52.com
Posted: Wed Nov 14, 2007 4:47 am Post subject: Yak'in Cross Country |
For those that have not viewed this site, here is a excellent weather site.
http://www.usairnet.com/weather/
Dennis
steve.fox(at)mac.com Guest
Posted: Wed Nov 14, 2007 6:11 am Post subject: Yak'in Cross Country |
As some one else with a short tank YAK, by the time Scott gets to PA he going to wish he talked to you long before he left
Scott, welcome to the East Coast. I will get Rob Mortara to add you to the NE Raiders list so you know what's going on in the neighborhood.
Fly safe and avoid I-got-to-get- there-itis.
All the best,
POTUS
On Nov 14, 2007, at 7:44 AM, A. Dennis Savarese wrote:
Scott,
When you get settled in PA, contact me off list and if you're interested, we can discuss the new fuel bladders for the 52. [b]
Posted: Wed Nov 14, 2007 6:28 am Post subject: Yak'in Cross Country |
Plan 150 nm legs and find fellow YAK owners along that route. That is incase
you do something like leave your air on or can't get her started and expend
you air. Do you have an adapter for your air system? Do you have the
Schrader conversion? If so and you have the stage one scuba yoke you can
make a adapter to service your air system.
Oil obviously is the other issue at 1 liter per hour. Not all FBO's are
going to carry 100 wt oil if you use Aeroshell or Phillips. Not sure what
you use.
Survival gear would be another thought. A SARSat ELT would be a definite for
me, flares, and thermal blanket that could be struck easily in a vest. Do
not know if you plan to fly with a Chute or not.
Others that have taken the Mountain routes can tell you about that. I have
not done that.
The rest, have fun. Your but and knees are definitely going to tell you just
sent on a ~1500nm XC.
david(at)mcgirt.net Guest
Posted: Wed Nov 14, 2007 6:39 am Post subject: Yak'in Cross Country |
If you need a Scott bottle to Scuba adapter "just in case" to borrow, let me
know, would be glad to lend it for your trip.
David McGirt
YK 52 TW
you use.
not done that.
ReadeG(at)Cairnwood.com Guest
Posted: Wed Nov 14, 2007 6:52 am Post subject: Yak'in Cross Country |
Scott:
Are you relocating to PA? We're based at KDYL - Doylestown, PA. Give
me a call when your local.
As for CC - we've done the trip three times in the Yak (also stock
configuration) using 70% and 232 kph it took 15 fuel stops. Using ~60%
it was 13 fuel stops. At 70% I planned 167 nm legs and rode the tail
wind using the GPS to gauge which airport to stop at. There are
sections where you'll have to short hop simply because there aren't
enough airports. Call ahead to check fuel. We made one stop where they
were out of fuel - that's not good news in a stock Yak to say the least.
You really appreciate winds aloft after the 4th stop or so!
I've only done the Route 80 in the Yak. I did ferry a Wilga from CA to
PA using the southern route - Apple Valley, Tuscon, Las Crusas, to Rt.
40, etc. Flying up through White Sands was quite something - we were in
the VFR corridor and saw a missile launch! That was a SLOW trip.
Reade Genzlinger
Cairnwood Cooperative Corporation
mailto:readeg(at)cairnwood.com
215.914.0370
Posted: Wed Nov 14, 2007 2:17 pm Post subject: Yak'in Cross Country |
I went west on 40 in Mary Alexanders Yak-50, and the airports I remember
going into were:
Shamrock Tx (A REAL lonely place)
Tucumcari NM (really friendly folks)
Double Eagle NM (LONG runway, pretty busy)
Gallup NM (Spent the night. Lots of Indians!)
Winslow Az (Where this girl in a pickup truck slowed down to take a look
at me)
Flagstaff Az (Just couldn't quite handle another leg without stopping
here.)
Kingman Az (Lots of dead airlines, lots of T-28's, lots of wind)
29 Palms Ca (No one there, buy fuel, take what you want, honor system...
Amazing)
Ramona Ca (Say hello to Vladimir Yastremski, Russian Master Mechanic)
Carried a really nifty small scuba bottle that was just enough for about
one emergency start.
Concur with the SARSAT. I also carried a .45 with about 100 rounds, and
a hand held VHF radio and TWO hand held GPS's.
Mark Bitterlich
Posted: Wed Nov 14, 2007 8:27 pm Post subject: Yak'in Cross Country |
I was not going to say anything about my 9mm with hollow points and two 14
shot clips! Concur with the handheld VHF (I carry a PRC 90 in my vest
pocket) along with all the other survival stuff. Flares (day and night),
whistle, signal mirror, magnesium striker fire starter, thermal blanket(that
is the bulky part) tucked in the back pouch, flashlight, water in aluminum
pouches, Iodine tablets, Ziploc plastic bags, fishing line with some hooks,
extra AA batteries, and hi protein energy bars. That is the contents of my
survival vest. Thought about an MRE but that really would be bulky.
Most of this stuff can be found at West Marine. The vest was an old one I
got from a Army Navy store. I had the inside line on the sale of some of our
old vests that were sold as surplus after we converted to a modular survival
vest.
The GPS handheld and or panel mounted is a given. Well maybe not but....
Do say anything about that Marine thing of never carry a weapon to a fight
that has anything less than a 4 in it. Those hollow points can do some
serious damage judging from a couple deer that were shot with them along
with one cotton mouth! I am currently looking for the "the Judge". A .410 6
shooter. It also will fire .45 rounds. The manufacturer has a 4 mo back log
of orders. That is a serious home protection weapon. Blows a 12 in diameter
hole in the target at 25 yards. Just an aside on my dream handgun.
Doc
jack
Posted: Wed Nov 14, 2007 8:42 pm Post subject: Yak'in Cross Country |
| Quote: | >..............a pickup truck <<
... flatbed ford, was it?
--- "Bitterlich, Mark G CIV Det Cherry Point, MALS-14
64E" <mark.bitterlich(at)navy.mil> wrote:
CIV Det Cherry Point, MALS-14 64E"
airports I remember
going into were:
down to take a look
at me)
without stopping
here.)
lots of wind)
Amazing)
Mark Bitterlich
shinden33
Posted: Wed Nov 14, 2007 11:14 pm Post subject: Yak'in Cross Country |
WOW! Thanks for all the gouge and invites guys & gals.
The websites will come in handy. I'm definitely going to take the southern
route - probably I40ish at least into TX.
I have a panel mount GPS but am planning on bringing a handheld as a backup.
I'm old fashioned and am taking paper charts as well.
Sorry folks, think I'm going to pass on the weaponry. If I get into that
kind of situation I've got bigger problems.
Water = Camelback. Camelbacks fit nicely behind the left shoulder so you can
even get to the H20 hose (and in some cases the pockets) in flight. They
will also hold a nice amount of energy bars, etc.
I'm looking at getting a pony SCUBA bottle for the trip. Anyone know where
I can get a 1st stage regulator cheap??? I have a adapter for my air system
but it doesn't have the Schrader valve. It just has an AN fitting.
The plan right now is ~130Nm legs to start and see how things go from there.
Day 1 (partial day) will be from L00 to Big Bear, to Parker AZ finally to
Deer Valley.
Flying with chutes and lots of memory foam.
See ya'll out there.
brian-1927(at)lloyd.com Guest
Posted: Thu Nov 15, 2007 9:06 am Post subject: Yak'in Cross Country |
On Nov 14, 2007, at 8:25 PM, Roger Kemp wrote:
| Quote: | Do say anything about that Marine thing of never carry a weapon to
a fight
I will go along with that. I have been an aficionado of the .45ACP
for as long as I can remember. A 1911A1 is my carry gun.
But I have been tempted to try something chambered for the .40cal S&W
round the FBI favors.
Brian Lloyd 3191 Western Drive
brian HYPHEN 1927 AT lloyd DOT com Cameron Park, CA 95682
— Antoine de Saint-Exupéry
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
Posted: Thu Nov 15, 2007 9:08 am Post subject: Yak'in Cross Country |
On Nov 14, 2007, at 11:13 PM, Shinden33 wrote:
southern
a backup.
I still fly with a paper chart in my lap. I am just too uncomfortable
any other way, even with all the electronics and moving map displays.
I have had my GPS receivers say, "we're done," too many times. I have
even had primary and backup GPS do it at the same time. I found the
chart, situational awareness, and an ADF to be very comforting.
| Quote: | Sorry folks, think I'm going to pass on the weaponry. If I get
into that
When you need one, nothing else will do. Look at it this way, it is
good for signaling as well as bringing down small game.
Posted: Thu Nov 15, 2007 10:07 am Post subject: Yak'in Cross Country |
And protecting one's self from 4 legged and 2 legged predators. A stick will
not get it with a pack of wild dogs. A few well placed rounds in the Alpha
male and even female will deter the pack for a while.
Doc
Posted: Thu Nov 15, 2007 2:25 pm Post subject: Yak'in Cross Country |
THAT'S RIGHT!
I wondered if ANYONE would catch that one! Good on you!
Mark
Posted: Thu Nov 15, 2007 2:40 pm Post subject: Yak'in Cross Country |
Weapons can be a pain in the tail to bring along, especially if you
don't have a concealed carry permit. I will tell you this... The folks
that live in the country you are about to fly over (past and present)
would not consider venturing past their fence posts without carrying at
the very least a side arm. However, if you are untrained and
uncomfortalbe with fire-arms in general, then you are right about not
carrying one. In that case, I'd recommend that you carry TWO SARSATS.
That way you stand a more than reasonsable chance of relying on society
to protect you from bad things.
You don't need a regulator on the Scuba pony tank. Or even a full sized
one. You just open the valve slowly and look at your cockpit gage.
When it gets near 50 atmos, close the valve. It's a no-brainer.
Good luck... When I took the same trip, it gave me wonderful memories
for years. You'll have a ball.
Mark
Posted: Thu Nov 15, 2007 2:45 pm Post subject: Yak'in Cross Country |
Brian, I would suggest you take a look at some of the Kimber models. I have a few. I think you'd love them.
Mark Bitterlich
