ron.mcgann(at)baesystems. Guest
Posted: Tue Nov 20, 2007 1:42 pm Post subject: Firewall penetrations |
G'day all,
I am about to work the firewall for wire and cable pass throughs. What penetration techniques have people found the best - eyeballs, s/s grommet covers, tube/firesleeve etc?
Are there any specific locations to avoid when making the penetrations? Is there a 'best spot'?
What is the best way to cut 'largish' holes (ie >1/2") into the stainless??
Thanks in advance for your suggestions.
Ron
187 finishing [quote]"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
ricksked(at)embarqmail.co Guest
Posted: Tue Nov 20, 2007 9:24 pm Post subject: Firewall penetrations |
Ron,
I used aluminum eyeballs for everything, it made getting the alignment a snap. I filled the aft pocket of the eyeball inside the cockpit with high temp silicone. I use a greenlee punch to make the holes, you drill a 3/4 hole with a unibit then use the punch, works great. I'll fwd some photos and shoot them out to you. I used the three triangle stacked in the recess for power, rpm and mixture. I use the upper left firewall for the purge control and low in the tunnel for the FAB aux air door. I also used the eyeballs for my battery and alternator lead penetrations. Granted these are a bit pricey, but they look good, allow for the cable to exit the firewall at it's best angle. The only thing that was a pain, not hard but time consuming was drilling out the balls for the cables or wire with the drill press.
Rick Sked
40185
AirMike
Posted: Wed Nov 21, 2007 7:51 am Post subject: Firewall penetrations |
Every RV builder should check out EPM-AVCORP.com before they start working on their FIREwall. Regardless of which way you go, you should have the information. This guy has done the research.
_________________ See you OSH '18
Q/B - sold. |
scottmschmidt(at)yahoo.co Guest
Posted: Wed Nov 21, 2007 9:13 am Post subject: Firewall penetrations |
http://www.epm-avcorp.com/tubeseal.html
I really liked these for all my wires. Just order the biggest one if you go this route. The smaller ones are much more difficult to work with. I used the eyeball style for my throttle, prop and mixture and for my three cables that power the electronic ignition.
http://www.scottandranae.smugmug.com/gallery/518426/1/53556340/Medium
Scott Schmidt
----- Original Message ----
Sent: Tuesday, November 20, 2007 2:37:04 PM
Subject: Firewall penetrations
G'day all,
Ron
187 finishing [quote]"Warning:The information contained in this email and any attached files isconfidential to BAE Systems Australia. If you are not the intendedrecipient, any use, disclosure or copying of this email or anyattachments is expressly prohibited. If you have received this emailin error, please notify us immediately. VIRUS: Every care has beentaken to ensure this email and its attachments are virus free,however, any loss or damage incurred in using this email is not thesender's responsibility. It is your responsibility to ensure viruschecks are completed before installing any data sent in this email toyour computer."[b]
