Tail Longeron bending
rv(at)thelefflers.com
PostPosted: Sun Nov 18, 2007 1:29 pm    Post subject: Tail Longeron bending Reply with quote
Any secrets to bending the longeron easily?
I seem to be banging on it without any results. I’m assuming that I must either start hitting with more force or get a heavier mallet.
rv10builder(at)verizon.ne
PostPosted: Sun Nov 18, 2007 2:19 pm    Post subject: Tail Longeron bending Reply with quote
I recall putting it on a vise and hitting it with a mallet, bend rather easily for me. I started close to the bending point and once I had the slight bend hit it hard a couple of times a little farther out. Pretty much followed the plans, as I recall.
If you have it positioned solidly in a vise hit it hard to get the initial bend going, should be easy after that.
Pascal
PostPosted: Sun Nov 18, 2007 2:32 pm    Post subject: Tail Longeron bending Reply with quote
The answer was obviously, just use a heavier mallet. I ran out a bought a much larger rubber mallet and bending became a non-issue.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Sunday, November 18, 2007 4:27 PM
Subject: Tail Longeron bending
__________ NOD32 2665 (20071117) Information __________
n212pj(at)gmail.com
PostPosted: Sun Nov 18, 2007 2:39 pm    Post subject: Tail Longeron bending Reply with quote
Pascal has it right. You might take a look at my pictures here: http://www.soundingsresearch.com/RV-10/Empennage/Tailcone/Tailcone06.htm
Use a shot filled mallet. Don't be shy. Just stress it in the right direction and whack it just in front of the vice jaws where you have it secured using the plastic or aluminum jaw inserts. Take your time and don't be nervous about it. It will bend.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal
Sent: Sunday, November 18, 2007 2:19 PM
Subject: Re: Tail Longeron bending
Pascal
poneill(at)irealms.com
PostPosted: Sun Nov 18, 2007 2:40 pm    Post subject: Tail Longeron bending Reply with quote
Be sure to preload it. I was timid about bending it at first and the mallet blows would slightly deflect the longeron but it would snap right back. If you preload it well first(bend it in the desired direction of bend with your free hand until it begins to strongly resist you), it bends very easily with each tap. So much so that I could see the bend occur with each blow. Once I figured out the preload amount, it was pretty easy to get the bend and correct any over bend and 90 degree deflection in the angle.
Just make sure that you have the bend mark aligned precisely where it is secured in the vise and it should go smoothly. If you go a little over, you can bend it back without issue (but try to minimize the mount of bends so you don’t overstress the material.) Just follow the same procedure.
At first I was not looking forward to this step, but after doing it, it was one of the easier and less problem prone tasks.
Best Regards,
Patrick #40715
Sent: Sunday, November 18, 2007 1:27 PM
PostPosted: Sun Nov 18, 2007 6:37 pm    Post subject: Tail Longeron bending Reply with quote
John;
Of course I'm right, I got the original information off your website!! speaking of which, when are you going to end the break and start the wings??
Pascal
Wings- half way there to being half done with them
John Kirkland
PostPosted: Mon Nov 19, 2007 6:23 pm    Post subject: Re: Tail Longeron bending Reply with quote
An interesting thing I noticed when I did this was that when I laid the longeron on the fuse skin to check the bend, I noticed the long straight part had a slight bow in it, so I carefully took that out too. Laying it on a flat table or bench with the fuse skin also lets you check it for twisting that might have occurred when beating the bend in it. I also got to take out a little bit of twist on one of mine.
RV-10 #40333
N540XP (reserved)
Deems Davis
PostPosted: Mon Nov 19, 2007 7:10 pm    Post subject: Tail Longeron bending Reply with quote
That's exactly how I remember it going, just when you get it to fit in
one axis, you check and the other is out, it took a series of back and
forth 'sessions' to get them to fit in both axis.
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
RV-10 #40333
N540XP (reserved)
PostPosted: Tue Nov 20, 2007 3:38 am    Post subject: Tail Longeron bending Reply with quote
Thanks for the info.....
I'll have to check the other axis. I did check the bend on a flat table,
but wasn't specifically looking at the other axis. I would hope that if it
was off, I would have noticed it. But I will check again just to be sure.
n212pj(at)gmail.com
PostPosted: Tue Nov 20, 2007 6:53 pm    Post subject: Tail Longeron bending Reply with quote
Pascal:
I originally had to go into hibernation on the build because my work sucked up all my time and energy. However, just recently another impediment came along. I hate to rent. All that good money going out the window, so, guess what? After whining about not having a plane to fly until some at the airpark ran the other way when I turned the corner, I finally bought myself a plane. I'm now am having so much fun flying that that and the job give me no time to build. I do love building though, so do plan on getting back to it. Maybe sometime this winter. Unless, of course, I decide to redo the panel on my new toy.
For those who might not know the type. This is a Glastar, 2-place. Built by a wonderful craftsman, Charlie Eubanks.
John Jessen
40328
Sent: Sunday, November 18, 2007 9:37 PM
John;
Pascal
 Filesize:  90.69 KB
 Viewed:  446 Time(s)
dlm46007(at)cox.net
PostPosted: Tue Nov 20, 2007 7:31 pm    Post subject: Tail Longeron bending Reply with quote
I concurr; mine goes up for sale as soon as the 10 flies about Jan 45. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen
Sent: Tuesday, November 20, 2007 7:52 PM
Subject: RE: Tail Longeron bending
Pascal:
John Jessen
40328
John;
Pascal
 Filesize:  49.56 KB
 Viewed:  462 Time(s)
robin1(at)mrmoisture.com
PostPosted: Tue Nov 20, 2007 8:41 pm    Post subject: Tail Longeron bending Reply with quote
Mine goes for sale around Q2 2008. www.painttheweb.com/rv-6a Significantly upgraded since photos. Dual Infinity Grips, Classic Aero Interior, EZ A/P & TT Alt Hold. Hardwired Garmin 396 RobinDo Not Archive
