oscardog
Posted: Sun Nov 18, 2007 10:51 am Post subject: Radio Noise |
[b][b]I have a problem of reported background noise and a weak transmission when I ask for a radio check which just started about 3 weeks ago. Prior to that checks were loud and clear.[/b]
[b]My engine is a Rotax 912ULS and I am sure it's engine noise that I am getting.[/b]
[b]My reception is fine on all channels I have tried. When I transmit, the red light on the Microair 760 Radio sort of blinks in time to a beep - beep in the headset. As I increase RPM on the 912 the beeps increase until they are almost a solid tone at around 5000 RPM.[/b]<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
[b]I am stumped so any suggestions to solve this you have are welcomed.[/b]
[/b]
nuckolls.bob(at)cox.net Guest
Posted: Sun Nov 18, 2007 8:34 pm Post subject: Radio Noise |
You need to investigate quality of your
power on the electrical system. With a
good battery in place and a properly
functioning alternator/regulator-rectifier,
there should be no way for the engine's
rpm to reflect upon your transmitter's
operation.
Check your alternator's output voltage under
full and light loads . . . make sure it's
stable. Put a known good "test" battery in
parallel with the ship's battery, or temporarily
replace the ships battery to see if it makes
a difference.
( -Thomas Paine 1776- )
jon(at)finleyweb.net Guest
Posted: Mon Nov 19, 2007 8:29 am Post subject: Radio Noise |
If the 912 uses resistor spark plug wires, you might try replacing them. Resistor wires are known to degrade over time.
I know nothing about the 912 so please disregard my comments if not applicable...
Jon
DO NOT ARCHIVE
