Throttle Cables
Troy Maynor
PostPosted: Thu Nov 15, 2007 7:14 pm    Post subject: Throttle Cables Reply with quote
Hi All,
I know this has been asked before but I never really got the details that I
need. I am grateful for the replies when we last discussed it however. I
don't want to start a big debate and beat the dead horse again but I need
relief. The questions revolve around changing the stranded or braided inner
thottle cables to solid ones to prevent possible kinking. Can the folks that
have already done this tell me the following? I am mostly interested in the
diameter of the solid wire that others have used successfully. Wicks has
.055" that should work with the factory outter housings,which is the
preferred in my opinion. Or, they also have .075" wire with thier 3/32" ID
housing. Which size is the best for routing without binding?
Troy Maynor
N120EU Europa Monowheel Classic
Left to finish:
Paint,(some) interior,engine install, (some) wiring.
Weaverville, NC USA
winmail.dat
 Filename:  winmail.dat
 Filesize:  2.09 KB
 Downloaded:  331 Time(s)
mau11(at)free.fr
PostPosted: Thu Nov 15, 2007 11:20 pm    Post subject: Throttle Cables Reply with quote
Hi TROY,
I replace the cables by stainless steel piano wire dia. 1.5 mm (about 0.059
inch) and use a graphite grease into the sleeve, in France winter is cold
currently -5 to -10°Celcius possible, this solution is perfect for me.
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com]De la part de Troy Maynor
Envoyé : vendredi 16 novembre 2007 04:08
À : europa-list(at)matronics.com
Objet : Throttle Cables
Hi All,
Troy Maynor
Left to finish:
Weaverville, NC USA
Gilles.Thesee(at)ac-greno
PostPosted: Sat Nov 17, 2007 9:53 am    Post subject: Throttle Cables Reply with quote
inch)
Michel, Troy and all
We are also using a 1.5 mm dia piano wire, along with many Rotax fellow
fliers.
Best regards,
Gilles
http://contrails.free.fr
