Michel
Posted: Thu Nov 15, 2007 4:49 am Post subject: News alerts "Kitfox " accidents |
I didn't get a Google Alert on that one, Dave. Probably because the
press didn't get involved and it may be just as well.
This is the first bird strike I read about with a Kitfox. Does anyone
know of any other? Is it a real danger? I was under the impression that
we fly too slow for, at least, big birds. Would reducing speed be a
good idea when birds are observed in the area?
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
_________________ Kitfox 3 - Jabiru 2200 |
dave
Posted: Thu Nov 15, 2007 5:42 am Post subject: Re: News alerts |
Michel , we have extensive bird activity in my area ( SW ontario, Canada) now for a month or so and likely will be for a while yet. I do a fair bit of flying and seagulls are everywhere. Alot of Canada Geese too but I find the seagulls more frequent. I just fly through them when i come across them as I figure they can turn quicker than me and likely they are more afraid of a larger "bird" . I have not hit one yet and hopefully will not.
That news though just shows you why forced approach training is a real attribute in the event of an emergency requiring a forced landing.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
lcfitt(at)sbcglobal.net Guest
Posted: Thu Nov 15, 2007 9:02 am Post subject: News alerts "Kitfox " accidents |
Michel,
Can't answer your question, but I nearly flew into what appears to be a Bald
Eagle apprpachoing a lake in Idaho a couple of years ago and there is a
short video clip on the HighWing LLC website go to
http://highwingllc.com/videoarchivepages/birdstrike.html
The bird's reaction to the "big bird" is typical as I understand.
Lowell
Float Flyr
Posted: Thu Nov 15, 2007 12:54 pm Post subject: News alerts "Kitfox " accidents |
I've had seagulls look inside the plane while flying. That's as close as is
comfortable.
Noel
Do not archive.
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
akanka(at)kiamichiwb.org Guest
Posted: Thu Nov 15, 2007 2:52 pm Post subject: News alerts "Kitfox " accidents |
Large birds (anything that weighs over a pound) can be a serious problem.
The faster the aircraft, the more damage they can do.
FWIW, here in Oklahoma (and in Texas as well), there are a lot of turkey
buzzards. Several years ago (30
plus), I was the pilot of a UH-1 helicopter at Ft. Hood, Texas. While in a
40 degree bank to the left and looking at the ground out the left side at
about 80 knots, the right front windshield was impacted by a buzzard. From
personal experience, I can attest that a turkey buzzard is about 10 pounds
of very smelly scat covered with black feathers, and has a bright red head.
I got several small lacerations from that thing landing in my lap, and
thankfully I was flying with a copilot that was on the controls at the time
of impact. I can assure you that I avoid any bird that I can see if
possible since then.
John Hart
Malcolmbru(at)aol.com Guest
Posted: Thu Nov 15, 2007 6:38 pm Post subject: News alerts "Kitfox " accidents |
several times in my old plane I could chase Canadian gees so hard they would fly down into wooded beaver flooding to get away from me. it took some hard turns and a good eye. but moor times than not I would loose them before that would happen mal
See [quote][b]
Float Flyr
Posted: Fri Nov 16, 2007 6:44 am Post subject: News alerts "Kitfox " accidents |
Mal:
You're lucky you live south of the 49th. Up here there are federal laws against interfering with wildlife in the manner you described. If you come up this way just steer clear of the birds and other wildlife.
Noel
Kitfox III-A
Bob
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Fri Nov 16, 2007 7:51 am Post subject: Re: News alerts |
Real danger? Usually just as very extensive leading edge or cowl damage, but absolutely!
Per http://www.birdstrike.org/
Over 195 people have been killed world-wide as a result of bird strikes since 1988.
An estimated 80% of bird strikes to civil aircraft in USA go unreported.
Waterfowl (31%), gulls (26%), and raptors (17%) represented 74% of the reported bird strikes causing damage to USA civil aircraft, 1990-2006.
A 12-lb Canada goose struck by a 150-mph aircraft at lift-off generates the force of a 1,000-lb weight dropped from a height of 10 feet.
Starlings are "feathered bullets", having a body density 27% higher than herring gulls.
As for a couple of reports at Kitfox speeds...
Cessna 152 OCT 2003
A Cessna 152 experienced a bird strike, forcing the pilot to make an emergency landing. VMC conditions prevailed at the time. The airplane sustained substantial damage. The airplane was found inverted; a quarter of the windshield was recovered. A bird was found in the airplane. The instructor stated that the student was practicing ground reference maneuvers at about 1,000 feet AGL at an indicated airspeed of 90 knots. While coming out of a left turn, a sudden noise followed by debris was felt in the cockpit. The instructor stated that the airplane was missing the windshield and he could not maintain altitude after applying full throttle. The airplane impacted a field nose first and came to a halt inverted. The instructor and student suffered minor injuries.
From an OH 58 (Jetranger equivalent) helicopter:
We were flying 700 AGL at 80 knots when suddenly there was a loud crash, and the right half of the windshield (pilot side) shattered, sending 80 percent of the Plexiglas windshield into the cockpit where it struck my face and chest. I quickly scanned the gauges and determined that the helicopter was still functioning.
Bob
Vixen partially completed, no engine
Damascus, MD
_________________ Remember that internet advice may only be worth what you pay. |
Michel
Posted: Sat Nov 17, 2007 12:25 am Post subject: News alerts "Kitfox " accidents |
On Nov 15, 2007, at 2:42 PM, dave wrote:
| Quote: | Michel , we have extensive bird activity in my area
On Nov 15, 2007, at 6:00 PM, Lowell Fitt wrote:
| Quote: | I nearly flew into what appears to be a Bald Eagle apprpachoing a lake
in Idaho
Thank you Dave and Lowell. I will be more on the look out for those
fellows in the future.
Michel Verheughe
Norway
FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Sat Nov 24, 2007 5:16 am Post subject: Re: News alerts |
We live on the Gulf Coast in Alabama and have an abundance of seagulls, pelicans, migratory geese/ducks, etc. Back in 1993 while flying my Quicksilver MX II down the beach of a long sandbar, I was hit in the chest by a seagull. I do NOT make a habit of flying close to birds...However this one came out of nowhere. I impacted the ground in a semi unconscious condition...still trying to fly the plane. Major damage to the plane and just bruising and a cut on my finger.
One thing to remember, NEVER attempt to fly under a bird! Birds dive to get away (quick increase in airspeed) from a potential danger. Seldom ever do they go up (while in level flight)...however......
Last year in my Vixen, flying this same stretch of beach with my new supervisor...taking her first "real" airplane flight... All things were going well. At around 200' MSL (there were no people on the beach of this island/sandbar) and at 110 MPH there were several seagulls that flew up from nowhere. I caught a quick glimpse of something and before I could do or say anything it/they...hit the prop on the left side of the plane then slammed against the glass on my door. I have those small swivel vents that have the 1/2 crescent shaped opening on each door... and when open have a small lip that extends outward about 1/2" to divert the air through the opening. The gull hit the lip and it shredded the carcase...a lot of which blew through the opening and sprayed the cockpit with seagull innards, blood, meat and partially digested fish/minnows. I throttled back and noted that there was no problem with the flight controls, etc. When I turned to my passenger...I couldn't believe my eyes. My new boss was coated from the chest up with the above mentioned particles. The first thing I told her was..."do not lick your lips!" She removed her glasses and the "clean" outline was almost perfect around her eyes! I reached behind the seat, pulled out a towel and she started wiping her face. It was really a goolish sight. We work in the healthcare industry so a little blood, guts and stinch was really not all that bad...for us...anyway!
My wife and I worked for over 5 hours cleaning the inside of the plane. ..it was EVERYWHERE! ...what a mess!
The next day I noticed a large blood stain on the right wing leading edge at the wing-tip cover. We had apparently hit more that one seagull. Yep, bird strikes are real and potentially devastating.
Honestly.....I hate seagulls...and it's obvious they hate me as well...because they are willing to sacrifice themselves to try to get me!
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
kitfoxmike
Posted: Sat Nov 24, 2007 8:31 am Post subject: Re: News alerts |
you mean one of these. Hit a little on the prop and then hit the side window, the underside of the wing and then laid rest here. Note the legs sticking up in the air, kind of cool. I heard the hit, that was all, never saw it.
2.14 MB |
800 Time(s) |
FlyboyTR
Posted: Sat Nov 24, 2007 8:40 am Post subject: Re: News alerts |
Mike,
Cool picture! ...much better on the outside of the plane...rather than being shredded and spewed inside through the vent! My wife just pointed out to me that we did have a piece of wing and leg...we think... jammed between the lift strut and the wind on the right side.
Again...nice pic! ...all of this sort of gives me a knot in my stomach!
Mobile, AL
ADI-II Autopilot
Guy Buchanan
Posted: Thu Dec 06, 2007 9:55 am Post subject: News alerts "Kitfox " accidents |
At 02:56 AM 12/6/2007, you wrote:
| Quote: | The airplane impacted the Columbia River, which shattered the
windshield and popped open both doors. The airplane sank immediately;
I always wondered if a Kitfox would float very long.
Guy Buchanan
San Diego, CA
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
dave
Posted: Thu Dec 06, 2007 10:34 am Post subject: Re: News alerts |
Guy Buchanan
San Diego, CA
Do not archive |
what is bouyant in the Kitfox other than trapped air > ?
- wood ribs , false ribs
-empty fuel tanks till the pitot allows water in.
- seat cushions?
-tires - likely Kingfox a little more bouyant
Michel
Posted: Thu Dec 06, 2007 12:19 pm Post subject: News alerts "Kitfox " accidents |
On Dec 6, 2007, at 7:34 PM, dave wrote:
| Quote: | what is bouyant in the Kitfox other than trapped air > ?
- seat cushions?
Buoyancy? I was once considering filling the fuselage with those
inflatable dolls, you know ...
.. Okay, I'll shut up!
Michel Verheughe
Norway
dave
Posted: Thu Dec 06, 2007 1:00 pm Post subject: Re: News alerts |
now that would be a you tube Kitfox Video !!
LOLLLLLLLLLLL
clint_bazzill(at)hotmail. Guest
Posted: Thu Dec 06, 2007 3:52 pm Post subject: News alerts "Kitfox " accidents |
Just long enough for the fuselage and wings to fill with water.
| Quote: | Subject: Re: News alerts "Kitfox " accidents
Date: Thu, 6 Dec 2007 10:34:25 -0800
--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com>
> Quote:
> Guy Buchanan
> San Diego, CA
> K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar.
> Do not archive
- seat cushions?
Rotax Dealer, Ontario Canada
Flying Videos and Kitfox Info
http://www.cfisher.com/
http://forums.matronics.com/viewtopic.php?p=150825#150825
&g========================
