john_graham
Joined: 09 Aug 2007 Posts: 45 Location: Algonquin, IL
Posted: Sat Nov 17, 2007 8:08 am Post subject: Carb heat |
No where have I read in any of the checklists when to
use carb heat or when it is recommended. Obviously I
would turn it ON if my engine was running rough or
stopped as part of the emergency procedures. But does
the M14 recommend the use of carb heat in the pattern?
I can't find mention of it.
John P. Graham
CubFlyer1940(at)Yahoo.com
Cell phone (847) 641-1330
Be a better sports nut! Let your teams follow you
with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
_________________ John Graham
N15YK 1993 Yak-52
CubFlyer1940@Yahoo.com
(847) 641-1330 |
cjpilot710(at)aol.com Guest
Posted: Sat Nov 17, 2007 9:19 am Post subject: Carb heat |
The CJ-6 has a carburetor temp gage. Watch it.
The M-14 normally does not need carb heat in the pattern.
The old rule of thumb for icing is if the OAT is 10C or lower AND there is visible moisture, (drizzle, fog, mist, etc), than there is a very good chance icing conditions. That is for airframe ice but take a look at you carburetor temp gage. If there is a marked arch on it, that is what you should be watching. The air temp as it passes though the carb drops considerable as it passes though the throat. Using the alternate air simply takes warmer air from behind the engine and runs it into the carb. In 1500 hours behind the HS6 and M14 I never had carb ice. That does NOT mean it will not happen since a number of folks have reported it here. But the airplane does have "alternate air". Years ago when I put the M14 on my CJ, I built a carb heat system. I should have stuck with just alternate air. It is simpler and because the pressure carbs, don't have icing problems as standard carbs, it would have been just as effective.
Jim "Pappy" Goolsby
In a message dated 11/17/2007 11:10:54 A.M. Eastern Standard Time, cubflyer1940(at)yahoo.com writes:
| Quote: | --> Yak-List message posted by: John Graham <cubflyer1940(at)yahoo.com>
John P. Graham
sp; (And Get Some AWESOME FREE find you for -Matt Dralle, List es y --> - MATRONICS WEB FORUMS ======================
brian-1927(at)lloyd.com Guest
Posted: Sat Nov 17, 2007 4:52 pm Post subject: Carb heat |
On Nov 17, 2007, at 8:08 AM, John Graham wrote:
There really isn't a need for carb-heat in our engines. In a standard
carb the fuel is metered into the venturi which is upstream of the
throttle valve. As the fuel evaporates it cools the air causing the
moisture in the air to turn to ice. The ice usually forms on the
throttle valve.
The pressure carb is really a single-point fuel injection system. The
fuel spraybar is downstream of the throttle valve and there is
nothing between the spraybar and the compressor impeller. There is no
chance of ice ever forming on the compressor impeller.
So the only time you really need carb heat is if the inlet itself
ices up (requiring alternate air) or if it is so cold that you need
extra heat to get the fuel to vaporize when the engine is first started.
Are there any other times? Probably, but I can't think of any.
Brian Lloyd 3191 Western Drive
brian HYPHEN 1927 AT lloyd DOT com Cameron Park, CA 95682
— Antoine de Saint-Exupéry
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
bpx2horn(at)aol.com Guest
Posted: Sun Nov 18, 2007 6:57 am Post subject: Carb heat |
I fly routinely in Northern Illinois and Southern Wisconsin in the extreme cold months of January and February. During these months in the event that a go-around is necessary, I and my teamates have found that applying carb heat on final helps to keep the engine from stuttering. I think Brian maybe right that after a low power setting the carb may cool a bit and the carb heat warms it enough to allow for better atomization of the fuel when dumping all that fuel in rapidly.
Paul Hornick
