jconnell(at)fmwildblue.co Guest
Posted: Sat Nov 10, 2007 11:13 pm Post subject: Does anyone trim the trailing edge of the main gear leg fair |
Gentlemen,
I've been searching the archives to no avail. The instructions for the
RV-9A say the following:
1. "Trace the root end, trailing edge, and tip end trim lines onto the fairing."
2. "Trim the root and tip ends of the fairing but do not trim the trailing edge."
I don't see any indication that I will ever trim the trailing edge. There is a
comment about using a long stick and sandpaper to remove excess "tail"
on the fairing and even the sides of the trailing edge.
Will any trailing edge material need to be removed before fitting the hinges?
Will any trailing edge material need to be removed to fit the ready-made
intersection fairings?
Many thanks.
Joe Connell
RV-9A N95JJ
