Power Diagram for peer review - Comments please
darinh
PostPosted: Tue Nov 13, 2007 12:31 pm    Post subject: Power Diagram for peer review - Comments please Reply with quote
here is yet another diagram for peer review. I am a novice at best in the electrical department and want this system to be accurate and reliable. I have used Bob's drawings to make this hybrid power diagram for my specific case.
As a background, here is what I am working with:
- Rotax 914
- External 40 Amp Alternator (primary)
- Rotax internal alternator (as backup)
- Single battery
My understanding is that the two alternators can be setup on switches and in the event that I have a failure of the primary, I can switch it off and switch on the backup. I pulled pieces and parts from various drawings and need someone or a couple someones to provide some review. I appreciate the help!
Rotax 914 Modified.pdf
 Filename:  Rotax 914 Modified.pdf
 Filesize:  135.4 KB
 Downloaded:  691 Time(s)
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
