johnd(at)data-tech.com Guest
Posted: Mon Aug 13, 2007 11:51 am Post subject: Z-20 System |
Hi All,
I'm getting ready for the electrical system in my zenith 601XL with a
Jabiru 3300.
I'm trying to keep things simple and am thinking about going with the
Z-20 Small Jabiru System. That diagram switches the main bus thru the
Master switch instead of a battery contactor. Whats the practical cutoff
in terms of current for using a contactor vs routing directly thru the
switch. Any downside to adding a contactor to this plan ? Any upsides ?
Any issues with the Z-20 plan ?
John Davis
Burnsville, NC
mosquito56
Posted: Tue Nov 13, 2007 2:45 pm Post subject: Re: Z-20 System |
I have just seen your post and I am also interested in the 601-Jab3300 z/20 diagram. I haven't seen any answers to your post but would like to know more about this diagram
Don
_________________ Don Merritt- Laredo, Tx
nuckolls.bob(at)cox.net Guest
Posted: Wed Nov 14, 2007 7:15 am Post subject: Z-20 System |
At 03:45 PM 8/13/2007 -0400, you wrote:
Hi All,
Jabiru 3300.
I'm trying to keep things simple and am thinking about going with the Z-20
Small Jabiru System. That diagram switches the main bus thru the Master
switch instead of a battery contactor. Whats the practical cutoff in terms
of current for using a contactor vs routing directly thru the switch. Any
The reason for NOT having a battery contactor in Z-20
is to eliminate the energy lost keeping a battery
contactor closed when that loss is a significant
total of the alternator's output. Figure Z-17 is
similarly devoid of battery contactor for the same
reason.
This architecture is appropriate to engines having
PM alternators on the order of 10A or less . . .
which means bus loads of 10A or less. This architecure
does not offer a secondary means for shutting the
system down in case of a stuck starter contactor
but these events are rare.
If you want a battery contactor, wire per Z-16 but
be sure to include battery contactor loads in your
calculations for equipment you plan to install
and your engine's ability to support those loads with
what ever alternator is installed.
( -Thomas Paine 1776- )
Posted: Wed Nov 14, 2007 7:17 am Post subject: Z-20 System |
At 02:45 PM 11/13/2007 -0800, you wrote:
<mosquito-56(at)hotmail.com>
Don
P.S. I just looked up the 3300 and find that it's alternator
is 15A continuous, 22A intermittent. Z-16 is the appropriate
architecture for this engine.
