dsmit132(at)bellsouth.net Guest
Posted: Mon Feb 20, 2006 12:57 pm Post subject: Z-14 FADEC Version Question |
Bob, Im building an RV-7A with a FADEC engine, one B&C 60A alternator and
two PC-680 batteries. Is there any reason I cant use the Z-14 FADEC Version
and just eliminate the aux. alternator and regulator?
Danny
nuckollsr(at)cox.net Guest
Posted: Mon Feb 20, 2006 3:38 pm Post subject: Z-14 FADEC Version Question |
At 02:56 PM 2/20/2006 -0600, you wrote:
<dsmit132(at)bellsouth.net>
What kind of engine? Do you plan a vacuum system?
dannylsmith
Joined: 21 Feb 2006 Posts: 9 Location: Panama City Beach, FL
Posted: Tue Feb 21, 2006 11:13 am Post subject: Re: Z-14 FADEC Version Question |
Sorry I didn't give you enough info Bob.
It's a Mattituck IOF-360 with B&C starter and 60A alternator - no vacumn or mechanical gyros. It's all electric - all glass panel. It will be IFR with Garmin GMA-340 Audio Panel, GNS-480 GPS/Nav/Com, GTX-330 Xpondr (Traffic), SL-40 Com, TruTrak DigiFlight II VSGS, TruTrak ADI, GRT 4000 EIS and two Horizon I EFISs with XM Weather. Much of this equipment will accept power from two sources. My backup to the Garmin equipment is the TruTrak ADI and the EIS 4000 option of AS and Altitude. Plus the TruTrak auto pilot.
My plan is to use the Figure Z-14 FADEC and eliminate the aux alternator and regulator.
Does this sound reasonable?
_________________ Danny |
Posted: Tue Feb 21, 2006 10:20 pm Post subject: Z-14 FADEC Version Question |
At 11:13 AM 2/21/2006 -0800, you wrote:
auto pilot.
and regulator.
Then what you REALLY need is Z13/8 with a second battery.
< with experiment. >
< --Lawrence M. Krauss >
dannylsmith
Posted: Wed Feb 22, 2006 11:31 am Post subject: Re: Z-14 FADEC Version Question |
| nuckollsr(at)cox.net wrote: | At 11:13 AM 2/21/2006 -0800, you wrote:
auto pilot.
and regulator.
You have me confused Bob. I have a FADEC so why would I use the Z-13/8 - all electric airplane on a budget with P-Mags instead of the Z-14 FADEC? I just felt that with a FADEC engine with two PC-680s that I don't need a second alternator.
Danny
< --Lawrence M. Krauss > |
Posted: Thu Feb 23, 2006 7:26 am Post subject: Z-14 FADEC Version Question |
At 11:31 AM 2/22/2006 -0800, you wrote:
will
> > auto pilot.
> > and regulator.
Your confusing the Z-figures as illustrations of ARCHITECTURE with
recommended combinations of hardware to end up in the finished
design. You don't HAVE to put p-mags in for Figure Z-13/8. Figure
Z-19 suggests an architecture for an electrically dependent engine
having one alternator and two batteries. But again, don't focus
on individual equipment items illustrated but the plan-a/plan-b
operational aspects offered by the architecture. Figure Z-14 with
a cross-feed contactor is an architecture for totally isolated,
independent, dual electrical systems. Since you plan only one
alternator, Z-14 is not applicable. In simplest terms, Z-19
is an expanded version of Z-11 with a second battery added along
with features to manage control and monitoring philosophies that
you may find attractive. I suggested Z-13/8 because you'll have
a vacuum pump pad with a cover plate over it. It seems a small
cost and weight penalty to take advantage of that pad with a
4# alternator installation. But Z-11 with dual batts, or Z-19
is closer to what you're looking for. You can always add the /8
feature to either system at a later date.
