Andair Fuel Valve - Redux
MauleDriver(at)nc.rr.com
PostPosted: Fri Nov 02, 2007 8:31 am    Post subject: Andair Fuel Valve - Redux Reply with quote
Thanks to all on list and off list that have helped me with the Andair
Fuel Valve acquisition. I have a valve which I will use. I would like
to use a 6" extension if I can get one easily.
If anyone has a Andair Fuel Selector Extension kit you'd like to sell,
please contact me.
Current status and findings:
After much back and forth and some cancelled orders to Andair, I bought
a unit from Vans:
Part Number: FUEL VALVE FS 20X7T
Quantity: 1
Unit Price: 205.00
Part Number: F SWIVEL TEE
Quantity: 1
Unit Price: 19.50
The 20X7T seems to me to be the best configuration whether you use or
extension or not. Vans said they still had a couple of dozen. The
price is right given current exchange rates with a savings of +$100 over
ordering direct from Andair. That difference is going to filter thru to
Van's inventory at some point so I'd go buy one if in the market. The
swivel T seems to be the optimal accessory for a fuel injected 540
installation.
The feeds from the tank are on elbows but the total cross section is
considerably less than using regular AN elbows threaded into the valve
body. I feel I can use this valve pretty easily with or without an
extension. I'll post a photo once installed. Thanks to all the others
who posted photos - invaluable!
Eric_Kallio
PostPosted: Sun Nov 04, 2007 12:16 pm    Post subject: Re: Andair Fuel Valve - Redux Reply with quote
I am in the same position as you are with the fuel valve. I am not as educated as some on the valves though, but can an extension be added to the ANDAIR valve Vans sells or does the valve have to be manufactured with it from the beginning. I assume it can be modified after manufacture but want to make sure before I buy the Vans valve and start looking for an extension.
Eric Kallio
PostPosted: Sun Nov 04, 2007 2:34 pm    Post subject: Andair Fuel Valve - Redux Reply with quote
According to information on the Andair website, extensions can be added
to the newer "Type B" valves. I bought a valve from Vans and confirmed
that it is a Type B (there is a detailed diagram and explanation on the
Andair site). It is exactly the same valve I would have configured if I
ordered directly from Andair
I've tried to locate an extension but cannot find one. So tomorrow I'm
going to order 1 direct from Andair.
I'll end up saving $100 minus shipping the extension over buying the
valve and extension from Andair.
Eric Kallio
http://forums.matronics.com/viewtopic.php?p=143813#143813
Tim Olson
PostPosted: Sun Nov 04, 2007 2:44 pm    Post subject: Andair Fuel Valve - Redux Reply with quote
Eric,
The valve extension is something that can be added later to the valve.
It comes with a different handle/bezel assembly that connects to the
extension. Shouldn't be any problem at all. Finding the extensions
in the U.S. might be the hard part. You'll probably end up
ordering them from Andair unless someone like Neal has them.
Eric Kallio
jfrjr(at)adelphia.net
I got an extension from Andy for $10.00. Ordered it at OSH when he was
there and he mailed it to me in a week or two. The ten spot included the
shipping. Jay Rowe #40301 (baffling)
 Filesize:  49 Bytes
 Viewed:  14302 Time(s)
kyrilian_av(at)yahoo.com
PostPosted: Sun Nov 04, 2007 4:46 pm    Post subject: Andair Fuel Valve - Redux Reply with quote
Hello All,
Aerocraftparts sells a L-R-Off valve that's used on the IO-540 powered Lancair Legacy. It has a 6-inch extension that may be appropriate to the RV-10. It lists for $365.
http://www.aerocraftparts.com/ItemForm.aspx?item=EFS25-2-2B-M
- Kyrilian
Lancair Legacy
Tim Olson <Tim(at)MyRV10.com> wrote:[quote] --> RV10-List message posted by: Tim Olson
Eric,
do not [quote][b]
PostPosted: Mon Nov 05, 2007 3:31 am    Post subject: Andair Fuel Valve - Redux Reply with quote
That would be nice! It looks like it's going to cost me $100 list after
applying the current exchange rate. BTW, Neal said he didn't have
anything any longer. Aircraft Spruce special orders them (with the
valve only).
Jay Rowe wrote:
[quote] I got an extension from Andy for $10.00. Ordered it at OSH when he
was there and he mailed it to me in a week or two. The ten spot
included the shipping. Jay Rowe #40301 (baffling)
Eric_Kallio
PostPosted: Mon Nov 05, 2007 5:03 am    Post subject: Re: Andair Fuel Valve - Redux Reply with quote
I ordered the valve from Vans and went ahead and just ordered the extension from Andair last night. That cost a pretty penny, but I wasn't able to find anyone that sold just the extension here in the states. Now all I need is a floscan and I can plumb my fuel system which is about all that is left before canopy.
Eric Kallio
40518 floors then fuel
PostPosted: Mon Nov 05, 2007 6:05 am    Post subject: Andair Fuel Valve - Redux Reply with quote
Re the Floscan - I've been told that they are setup for specific EISs.
That is, you get a Flo-scan setup for GRT or for ? or ?. Stein
confirmed this and sold one to me for the GRT. If all that is true, you
have to make a EIS choice before committing to the Flo-scan.
Seems like we're at the same place.
Eric Kallio
http://forums.matronics.com/viewtopic.php?p=143939#143939
orchidman
PostPosted: Mon Nov 05, 2007 6:30 am    Post subject: Re: Andair Fuel Valve - Redux Reply with quote
I am going AFS and it is included in their probes and sensors kit. So I would agree that you need to figure out which EIS you are going with because it may already be included.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
Tim Olson
PostPosted: Mon Nov 05, 2007 6:48 am    Post subject: Andair Fuel Valve - Redux Reply with quote
When I bought the Chelton system one of the things that I did
was buy the EIS6000 Chelton version, which adds a small
bit of software function to the standard, plus, it came with
all probes and sensors as well. So yup, good idea to have
your engine monitor picked out.
Now that said, a builder shouldn't be concerned about leaving
the fuel flow sensor for later, either. Doesn't matter
if you install it in the tunnel or on the engine, it won't
be nearly as tough as some items to install. So just cap the
lines, and wait until you pick your avionics, and install
it when you get the rest. You don't want to make hasty
avionics choices just because you want a flow sensor.
I ended up buying a spare, so I installed one and had one
that came with my system. Many of the EIS's use the same
FloScan anyway.
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
http://forums.matronics.com/viewtopic.php?p=143956#143956
orchidman
PostPosted: Mon Nov 05, 2007 8:32 am    Post subject: Re: Andair Fuel Valve - Redux Reply with quote
Another comment, there are 2 different bolt/nut plate patterns on the mounting bracket. I was lucky in that the AFS flowscan takes the alternate mounting pattern and I had just received it when I was at that point in Section 28.
So if you don't know which you will be using, you might want to leave the bracket off and then rivet it on when you know what you are going to do for sure.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
greytex
PostPosted: Mon Nov 05, 2007 8:52 am    Post subject: Andair Fuel Valve - Redux Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Back to the Andair valve. I ordered the pricey extension kit from them 2 months ago and have never received it. we are in the email back and forth stage now. I asked them to track it for me with no luck so far. just sent off a new request this am. will keep list informed of the drama as it unfolds.
John Cram
40569- Nick is going to final mount the top this week. (I am out of town working)
Tim Olson
PostPosted: Mon Nov 05, 2007 9:06 am    Post subject: Andair Fuel Valve - Redux Reply with quote
They aren't the quickest responding company, that's for sure.
I actually phoned them a few times as well, using an AT&T
calling card. I figured it was worth poking them a bit.
They did come through in the end. I get the feeling that
they're highly reliant on a few specific individuals.
John Cram wrote:
[quote] Back to the Andair valve. I ordered the pricey extension kit from them 2
John Cram
working)
Eric_Kallio
PostPosted: Mon Nov 05, 2007 12:22 pm    Post subject: Re: Andair Fuel Valve - Redux Reply with quote
I am going withe the new GRT HX and have been on their website looking at their floscan (fuel flow package). Just haven't placed the order yet though. I figured that I had time since Andair typically takes a good while to ship.
Eric Kallio
greytex
PostPosted: Tue Nov 06, 2007 7:23 am    Post subject: Andair Fuel Valve - Redux Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I just received an email from Owen at Andair. They are resending me my order, this time by UPS. All is good.
John Cram
40569
