Strengthen mod for rudder pedals
kentk
PostPosted: Thu Nov 01, 2007 4:49 pm    Post subject: Strengthen mod for rudder pedals Reply with quote
Can someone tell me what I need to do to get the updated rudder pedals? I was told that the pedals need to have triangular supports welded to the posts. Is this something that I need to do, or do I need to acquire new ones from KitFox.
Kent Knudsen
College Station, TX
K-IV 1200 / no engine / 25% done
lcfitt(at)sbcglobal.net
PostPosted: Thu Nov 01, 2007 6:46 pm    Post subject: Strengthen mod for rudder pedals Reply with quote
Ken,
There are several ways to strengthen the rudder pedal weldments. Attached
are photos of my method - I fabricated the reinforcements and found a
certified welder to put them together. The metal is 4130 and exactoy the
same thickness as the pedal tubing.
Lowell
 Filesize:  61.96 KB
 Viewed:  750 Time(s)
 Filesize:  48.87 KB
 Viewed:  713 Time(s)
 Filesize:  58.39 KB
 Viewed:  703 Time(s)
Tom Jones
PostPosted: Thu Nov 01, 2007 7:17 pm    Post subject: Re: Strengthen mod for rudder pedals Reply with quote
Kent, you can reinforce your rudder pedals for much less than the cost of new ones. I purchased the 4130 plate and cut it to fit then had a welder do the welding. The hardest part was sanding the powder coating off before I took them to the welding shop. I think some people use smaller triangles than I did. Mine might be a little overkill. picture attached.
 Filesize:  877.14 KB
 Viewed:  742 Time(s)
Tom Jones
Classic IV
Ellensburg, WA
Tom Jones
PostPosted: Thu Nov 01, 2007 7:56 pm    Post subject: Re: Strengthen mod for rudder pedals Reply with quote
Here's another photo that shows a 4130 strap welded on the back of the rudder cable arm where it attaches to the rudder pedal.
 Filesize:  359.44 KB
 Viewed:  733 Time(s)
Tom Jones
Classic IV
Ellensburg, WA
kentk
PostPosted: Thu Nov 01, 2007 10:07 pm    Post subject: Re: Strengthen mod for rudder pedals Reply with quote
Awesome! Thanks for the tips! That is why I love this forum. Can hardly wait to get this project done and in the air.
Kent Knudsen
College Station, TX
