TruTrak Pitch servo installation
AirMike
PostPosted: Mon Oct 29, 2007 6:43 pm    Post subject: TruTrak Pitch servo installation Reply with quote
I am having a problem with the install of the (what should be easy) TruTrak Pitch servo. The problem is that the Aluminum spacer that they include is too long. I only have about .28" of space between the bellcrank bracket and the MM-3-300 rod end bearing. The TruTrak Pitch servo plans call for a (supplied) .438" spacer in that space. If I put in that thick of a spacer the whole thing would be very cattywhompus and would stress the drive on the servo and the bearing on the bellcrank. (Yes, I did double check to see that I reinstalled the drive wheel properly)
If anyone has had the same issue please let me know.
Also, as this has been an all day ordeal - calling Zach at Trutrak three times today, I intend to post installation instructions for the servo tomorrow.
See you OSH '18
Q/B - sold.
Tim Olson
PostPosted: Tue Oct 30, 2007 7:41 pm    Post subject: TruTrak Pitch servo installation Reply with quote
Do you have photos? I'm wondering, are you talking about the system
that uses a roller wheel that runs over a cable inside an aluminum
channel? It's a torque enhancing pitch mechanism? I'm having better
luck with that one than the original pushrod-only one.
servo tomorrow.
-------- OSH '08 or Bust Q/B Kit - Doors/windows/uggg
http://forums.matronics.com/viewtopic.php?p=142663#142663
aarongleixner(at)sbcgloba
PostPosted: Thu Nov 01, 2007 4:50 pm    Post subject: TruTrak Pitch servo installation Reply with quote
I installed my system last week (its the latest version with the wheel and cable), and had the exact same issue. I just shortened the spacer to the length that made it work. Let me know if I missed something.
Aaron
AirMike <Mikeabel(at)Pacbell.net> wrote:
[quote]--> RV10-List message posted by: "AirMike"
I am having a problem with the install of the (what should be easy) TruTrak Pitch servo. The problem is that the Aluminum spacer that they include is too long. I only have about .28" of space between the bellcrank bracket and the MM-3-300 rod end bearing. The TruTrak Pitch servo plans call for a (supplied) .438" spacer in that space. If I put in that thick of a spacer the whole thing would be very cattywhompus and would stress the drive on the servo and the bearing on the [quote][b]
dlm46007(at)cox.net
PostPosted: Thu Nov 01, 2007 6:17 pm    Post subject: TruTrak Pitch servo installation Reply with quote
I haven't been following the TT pitch servo thread but whatever you do make sure that the servo can not get into an over center lock. A locked elevator means pruning of the gene pool.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Aaron Gleixner
Sent: Thursday, November 01, 2007 5:49 PM
Subject: Re: TruTrak Pitch servo installation
Aaron
acs(at)acspropeller.com.a
PostPosted: Thu Nov 01, 2007 8:47 pm    Post subject: TruTrak Pitch servo installation Reply with quote
I had a look at my spacer on the servo last night and I would say it’s definitely closer to the .438” size rather than the .280” as Mike has described.
All is square.
I would check with TruTrak until they can identify to your satisfaction, what has changed.
John 40315
Sent: Friday, 2 November 2007 10:49 AM
Aaron
  - The RV10-List Email Forum ---> http://www.matronics.com/Navigator?RV10-List
4[b]
