jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Wed Oct 31, 2007 11:13 am Post subject: Cuyuna UL II-02 wiring diagram anyone? |
Does anyone have any info on the Cuyuna UL II-02 ignition wires?
Since I put the engine back on the plane I forgot which wire goes to the Ignition kill switch, and the rpm.
Also seems like there are more connectors than I am using and wonder what the others are for?
I also bought a Stratomaster E1 digital 3 1/2" instrument that will display my EGT's, CHT's, Engine Time, Flight timer and RPM (does water temp and Oil Presure to if you have them) all in a single nice compact package for $199.
I plan on powering it by a separate 9.6 volt 1400 mah NiMH battery from the hobby shop. Weighs about a pound and will help keep me Part 103 Ultralight, as opposed to a typical heavier 12v battery.
It will provide 24+ hrs of use before I need to recharge the battery, so I'll just bring it along with my handheld radio for charging before flying.
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
jb92563
Posted: Mon Nov 05, 2007 12:57 pm Post subject: Re: Cuyuna UL II-02 wiring diagram anyone? |
Thanks for your responses.
I have what I need now, a couple different but substantially similar schematics that allowed me to figure out the proper connections
for my engine.
Your help has been appreciated.
12.85 KB |
497 Time(s) |
Moni MotorGlider
Do Not Archive |
