Engine Analyzer
Goto page 1, 2  Next
rcdettmer(at)charter.net
PostPosted: Wed Oct 31, 2007 10:41 am    Post subject: Engine Analyzer Reply with quote
I am looking at installing an engine analyzer on my 680F when I hang the re-built engines in several weeks. Any advice out there on recommended systems and prices..?? John Vormbaum, I believe that you had a system installed on your 500B. What system was it and how much did it cost..?? I am also interested in any advice from you experienced geared Commander guys about recommended procedures for breaking in and operating the new engines. You can believe that I will want to be VERY conservative in treating those engines with TLC. Thanks.
<![if !supportEmptyParas]> <![endif]>
Randy Dettmer, AIA
680F / N6253X
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->[img]cid:image001.gif(at)01C81BB2.DF3832F0[/img]
663 Hill Street, San Luis Obispo, CA 93405
805 541 4864 / Fax 805 541 4865
http://www.dettmerarchitecture.com/
<![endif]--><![if !supportEmptyParas]> <![endif]>
 Filesize:  2.97 KB
 Viewed:  10441 Time(s)
bobf(at)feldtman.com
PostPosted: Wed Oct 31, 2007 10:54 am    Post subject: Engine Analyzer Reply with quote
kamala(at)MSN.COM
PostPosted: Wed Oct 31, 2007 11:49 am    Post subject: Engine Analyzer Reply with quote
rd, i have found the JPI units to be very helpful on three different aircraft. mason
Subject: Engine Analyzer
Date: Wed, 31 Oct 2007 11:40:52 -0700
.ExternalClass .EC_shape {;} .ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:11.0pt;font-family:Arial;color:#333333;} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:purple;text-decoration:underline;text-underline:single;} .ExternalClass EC_p.MsoAutoSig, .ExternalClass EC_li.MsoAutoSig, .ExternalClass EC_div.MsoAutoSig {margin-bottom:.0001pt;font-size:11.0pt;font-family:Arial;color:#333333;} .ExternalClass EC_span.EmailStyle15 {color:black;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass EC_div.Section1 {page:Section1;}
Randy Dettmer, AIA
680F / N6253X
 Filesize:  2.97 KB
 Viewed:  10432 Time(s)
John Vormbaum
PostPosted: Wed Oct 31, 2007 1:28 pm    Post subject: Engine Analyzer Reply with quote
Hi Randy,
I had the JPI EDM-760 Twin engine analyzer put in my airplane last year.
It cost ~$5k IIRC, and it's worth every penny. You could do it for less,
but I added on the optional fuel totalizer, and I love it. The JPI is a
very capable unit (moreso than the EI units I compared them to) and I
really like the software that comes with it, allowing you to download
all your flight history & engine behavior.
I HIGHLY recommend it. If nothing else, it'll pay for itself in fuel in
a few years.
/John
aircraft. mason
Randy Dettmer, AIA
680F / N6253X
*663 Hill Street, San Luis Obispo, CA 93405*
*805 541 4864 / Fax 805 541 4865*
*http://www.dettmerarchitecture.com/***
__________ NOD32 2521 (20070911) Information __________
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Wed Oct 31, 2007 1:32 pm    Post subject: Engine Analyzer Reply with quote
Was that $5K installed or uninstalled..?? Thanks.
RD
kamala(at)MSN.COM
PostPosted: Wed Oct 31, 2007 1:46 pm    Post subject: Engine Analyzer Reply with quote
rd, one unit per side has worked out well. mason to see commander aero install google 2001M
> Date: Wed, 31 Oct 2007 14:26:12 -0700
Subject: Re: Commander-List: Engine Analyzer
--> Commander-List message posted by: John Vormbaum <john(at)vormbaum.com>
Hi Randy,
a few years.
/John
> aircraft. mason
> From: rcdettmer(at)charter.net
> To: commander-list(at)matronics.com
> Randy Dettmer, AIA
> 680F / N6253X
&gt=
John Vormbaum
PostPosted: Wed Oct 31, 2007 1:55 pm    Post subject: Engine Analyzer Reply with quote
Installed, had it done during my last annual.
RD
PostPosted: Wed Oct 31, 2007 2:03 pm    Post subject: Engine Analyzer Reply with quote
I am getting quoted over $8K by my shop in Salinas - $4345 for the unit from
JPI (including a $300 JPI rebate) and about $4K to install. I am looking at
12 pair of wires from each engine (or more) routed to the panel. Is that
the same for your installation..??
BillLeff1(at)aol.com
PostPosted: Wed Oct 31, 2007 8:34 pm    Post subject: Engine Analyzer Reply with quote
Do not run on ground except to check operation and leaks. In the air lots of airspeed, lots of power and lots of fuel. This will seat the rings in without glazing the cylinder walls. Make fine adjustments after break-in flight. Again don't let it get hot on the ground while making the adjustments. The Overhauled fuel injectors will be 10% rich because they are set up for 680FL's with Big air Scoops. Lean it on ground for proper operation, get it in the air and adjust it later.
Bill Leff
See what's [quote][b]
rsrandazzo(at)precisionma
PostPosted: Thu Nov 01, 2007 12:44 am    Post subject: Engine Analyzer Reply with quote
Guys-
We installed a Gemini in N414C, and I’ve found it to be a superb instrument. We obtained it at a heavy discount through a personal contact- and after a brief seven hours of flight time in the airplane- I can’t imagine not having had one installed before. The one down side to the instrument is that they married themselves to a data extraction tool that effectively became outmoded a while back- but they haven’t taken it out of their literature yet- so all the data logging I was hoping for has not materialized.
In this respect I wish we’d gotten the JPI- as the data logging functions on that device still work.
As for the operation and functionality of the instrument- I think very highly of it!
We’re currently discussing having one installed on the SNJ… It may be smart to wait for the next engine overhaul, however.
Robert S. Randazzo
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of MASON CHEVAILLIER
Sent: Wednesday, October 31, 2007 2:46 PM
Subject: RE: Engine Analyzer
> From: john(at)vormbaum.com
> Subject: Re: Engine Analyzer
> Hi Randy,
> a few years.
> /John
> > aircraft. mason
> > Randy Dettmer, AIA
> > 680F / N6253X
__________ NOD32 2630 (20071031) Information __________
steve2(at)sover.net
PostPosted: Sat Nov 03, 2007 9:04 am    Post subject: Engine Analyzer Reply with quote
We've got the Insight GEM 1200. The gizmo itself works well enough, but for years Insight has not released theri proprietary data encryption and its pissed a lot of people off who have these things.
One of the neat things these things will do is store all your engine parameters for retrival later where you can dump it into spreadsheets and other applications. Insight was locking you into some ancient HP calculator with an infra-red port. Maybe things have changed. We haven't looked for over a year now. But it might be worthwhile to ask about data retrieval before purchasing. It would be fascinating to 'read' all the parameters that lead up to your failure. (Particularly if I'm not having to pay for those engines!)
Steve
 Filesize:  2.97 KB
 Viewed:  10433 Time(s)
andrew.bridget(at)telus.n
PostPosted: Sat Nov 03, 2007 10:03 am    Post subject: Engine Analyzer Reply with quote
Randy, my brother was looking at an AuRacle engine analyser for his Twin Comanche; didn't end up buying one in the end - they were all too expensive in South Africa. He said that, given the resources, the AuRacle would likely be his choice. It has USB transfer and apparently is (software) upgradeable via USB too. Don't know anything else about it.
<![if !supportEmptyParas]><![endif]><![if !supportEmptyParas]><![endif]> AUTOTEXTLIST \s "E-mail Signature" <![endif]--><![if !supportEmptyParas]><![endif]><![endif]--><![if !supportEmptyParas]><![endif]> God bless,
Andrew
PostPosted: Sun Nov 04, 2007 7:52 am    Post subject: Engine Analyzer Reply with quote
Thanks Andrew for the response. I am leaning towards a JPI unit at this time. So far I have heard many positive things about JPI. Still doing research.
Randy
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->[img]cid:image001.gif(at)01C81EB7.9D395D90[/img]
Dettmer Architecture
-----Original Message-----
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of andrew.bridget(at)telus.net
Sent: Saturday, November 03, 2007 11:02 AM
AUTOTEXTLIST \s "E-mail Signature" <![endif]--><![endif]-->
God bless,
Andrew
<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!) November is the Annual List Fund Raiser. Click on the Contribution link below to find out more about this year's Terrific Free Incentive Gifts! List Contribution Web Site: --> http://www.matronics.com/contribution Thank you for your generous support!     -Matt Dralle, List Admin. - The Commander-List Email Forum - --> http://www.matronics.com/Navigator?Commander-List   - MATRONICS WEB FORUMS - --> http://forums.matronics.com<![if !supportEmptyParas]> <![endif]>
 Filesize:  2.97 KB
 Viewed:  10425 Time(s)
John Vormbaum
PostPosted: Sun Nov 04, 2007 8:46 am    Post subject: Engine Analyzer Reply with quote
Randy,
I still feel strongly that the JPI is the one to get for these reasons:
1) It's a TWIN model, you only need to occupy one hole in your panel
2) The built-in fuel totalizer is great
3) The data logging & retrieval functions work perfectly (I love that
feature) via RS-232 to Serial cable.
I just bring my laptop in the airplane every now & then and download all
the data. The software provided by JPI is great, I can graph CHT, EGT,
Fuel flow, and break them down any way I want. Makes a bad plug, failing
valve etc. very easy to detect....before it fails.
Here are a couple of articles on engine management where the JPI plays a
big part. I like John Deakin's work and tend to agree with him,
especially vs. the Old Wives' Tales that Lycoming and Continental
occasionally still spew:
http://www.avweb.com/news/pelican/182176-1.html (Good graphics of the
JPI software graphs)
http://www.avweb.com/news/pelican/182084-1.html (Love this one, it's the
LOP vs. ROP argument)
Here's a link to all Deakin's articles. The JPI appears in many:
http://www.avweb.com/news/pelican/182544-1.html
Incidentally, I got quite a break on the price. I have been told that a
JPI install is roughly 40 hrs. At today's shop rates, your $8k estimate
is about right.
/John
doing research.
Randy
*Dettmer Architecture*
PostPosted: Sun Nov 04, 2007 2:47 pm    Post subject: Engine Analyzer Reply with quote
Hi Randy... just as well - apparently I was talking through my hat. My brother tells me that, while the download features are good on the AuRacle, it is only available for a limited number of aircraft. <![if !supportEmptyParas]><![endif]><![if !supportEmptyParas]><![endif]> AUTOTEXTLIST \s "E-mail Signature" <![endif]--><![if !supportEmptyParas]><![endif]><![endif]--><![if !supportEmptyParas]><![endif]><![if !supportEmptyParas]><![endif]> AUTOTEXTLIST \s "E-mail Signature" <![endif]--><![endif]--><![if !supportEmptyParas]><![endif]><![if !supportEmptyParas]><![endif]><![if !supportEmptyParas]><![endif]>
God bless,
Andrew
n395v
PostPosted: Sun Nov 04, 2007 4:41 pm    Post subject: Re: Engine Analyzer Reply with quote
JPI JPI JPI JPI
Milt
nico(at)cybersuperstore.c
PostPosted: Mon Nov 05, 2007 6:56 am    Post subject: Engine Analyzer Reply with quote
Randy,
Just as a matter of (academic, I suppose) interest, did you consider
replacing the engines with the Mr. RPM 800HP conversion?
Nico
PostPosted: Mon Nov 05, 2007 7:06 am    Post subject: Engine Analyzer Reply with quote
Hi Nico,
No, I didn't. Interesting idea, though. How many hundreds of thousands of
dollars would the Mr. RPM's cost..?? I have heard them mentioned many times
on this list, and assume that the performance upgrade is significant.
RD
PostPosted: Mon Nov 05, 2007 8:00 am    Post subject: Engine Analyzer Reply with quote
Hi Randy,
You can visit the commander website (www.aerocommander.com) and follow the
link STC Holders, which will lead you to Dick MacCoon's website with his
Commander STC's.
I am sure he will be able to provide you with more knowledgeable information
than I can. It might be worth a visit.
There is a video of the Orenda-engined Commander flying, too. Last time I
checked, it was for sale.
It would be interesting to hear your perceptions on the 800hp conversion.
Nico
kamala(at)MSN.COM
PostPosted: Mon Nov 05, 2007 8:03 am    Post subject: Engine Analyzer Reply with quote
rd, two (2). pls call if you wish to visit about it. mason 817-517-4977
[quote] To: commander-list(at)matronics.com
Date: Mon, 5 Nov 2007 07:06:00 -0800
--> Commander-List message posted by: "Randy Dettmer, AIA" <rcdettmer(at)charter.net>
Hi Nico,
RD
Goto page 1, 2  Next
Page 1 of 2
