Primer preparation question/ WD415 Trim Cable Anchor Bracke
ogdenk
PostPosted: Mon Oct 29, 2007 9:02 am    Post subject: Primer preparation question/ WD415 Trim Cable Anchor Bracke Reply with quote
Ed,
I am using Akzo, but haven't gotten to any of the non powder-coated steel parts yet.  I was looking at the trim cable anchor bracket the other day (I'm not too far from that point) and thinking about that though.  I think I will just clean the parts really well, then use a q-tip or something to put a thin layer of grease just in the threads so that the primer doesn't stick there.  Seems like there should be a better way though.  I also thought about putting a sacrificial bolt or piece of threaded rods in to keep the threads clean.  Might be hard to get out if you need to back primed threads through the part.
I was also looking at the trim cable anchor bracket and wondering about its durability.  This part looks like something I could have made in shop class, and doesn't give a feeling that it is very robust like other parts on the plane.  Is anyone aware of a 3rd party vendor replacement for this piece?  I thought I remember something like this from a while ago but maybe it's just my poor memory at work.
Kent Ogden
40710
>> Ed Godfrey <egodfrey(at)ameritech.net> 10/29/07 10:46 AM >>>
--> RV10-List message posted by: Ed Godfrey <egodfrey(at)ameritech.net>
Listers,
    For all of you who have primed your parts with Akzo, how did you
deal the steel parts, such as the nut plates and the WD-415 Trim Cable
Anchor Bracket?
Ed Godfrey
40717
_-============================================================
_-=          - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as the Subscriptions page,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=   --> http://www.matronics.com/Navigator?RV10-List
_-=              - NEW MATRONICS WEB FORUMS -
_-= Same great content now also available via the Web Forums!
_-=   --> http://forums.matronics.com
