Posted: Mon Oct 29, 2007 4:49 am Post subject: GX-60 - simulating speed on the ground |
Fellow tron-chasers,
I'm doing some autopilot testing in the hangar to make sure that things are commanded as designed.
One of the tests involves GPS steering (S-Tec System 30 with GPSS) and requires velocity to a destination in order to send proper signals to the steering converter.
Has anyone been able to get their GX60 to think it's moving in order to output roll signals?
Ralph Capen
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Mon Oct 29, 2007 6:05 am Post subject: GX-60 - simulating speed on the ground |
I don't know if it will do what you need but there is a simulator mode. It's
controlled by a jumper on the connector. Pin 7 on the 37 pin connector goes
to ground (pin 25) for normal operation. If open it's in simulator mode.
Greg Young
[quote] --
Posted: Mon Oct 29, 2007 6:16 am Post subject: GX-60 - simulating speed on the ground |
I'll look it up and try it - thanks
