Colin K.
Posted: Fri Oct 26, 2007 2:57 pm Post subject: Tools |
Would those of you who have built please give some advice about tools, especially for the fiberglass work?
I am about to start buying my cutting/sanding tools, in anticipation of the kit arrival by the end of November, and would appreciate any recommendation you would share.
The build manual provides a basic list of tools, but are there any models better than others, or with the actual cutting, drilling, sawing bits, is there any material or courseness that works better on fiberglass?
Colin K.
OK
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
_________________ Colin K.
OK |
wb2ssj(at)earthlink.net Guest
Posted: Fri Oct 26, 2007 4:09 pm Post subject: Tools |
Tools
1. "permagit" tools for fiberglass (both sets, fine and coarse)
2. An air grinder with cut off blades
3. A "dremel tool" with the sanding drums
4. A set of 12" sanding blocks that use "Norton" sand paper that comes in rolls and has stickem on the back. 120 & 220 grirt.
These are the most important as I use them constantly.
Tex
