rcnewman(at)mycingular.bl Guest
Posted: Wed Oct 24, 2007 11:55 am Post subject: New product annoucement |
Fellow RV builders,
I'm pleased to annouce we have added two new models to the Safety-Trim product family. In addition to our standard features of time limited servo control, adjustable speed control, emergency reverse and simplified pilot/co-pilot wiring we now have models with that provide 2 user adjustable preset speeds. This feature allows you to control your trim response based on aircraft performance. This feature is especially useful in aircraft with a large performance envelope such as the RVs.
For all the details please visit our website. www.tcwtech.com
Bob Newman. Rv-10
#40176
Sent via BlackBerry by AT&T
teyoung1(at)comcast.net Guest
Posted: Thu Oct 25, 2007 10:50 am Post subject: New product annoucement |
I'd be interested to know if anyone has tried a two-speed setup using a
5-position inline switch like this (51MX down at the bottom):
http://www.machinecomp.com/js_sa.htm
First position, slow, push it a little farther, fast. It might be one of
those ideas that seems clever but isn't, but I can't really see why it
wouldn't work. Any thoughts?
Tom Young
RV-4, long, long way to go
Posted: Thu Oct 25, 2007 1:03 pm Post subject: New product annoucement |
Tom, The component you found is a multi-position switch. Although it can select multiple actions it has no way of providing any speed control function on its own. Additionally, it does not provide any of the valuable features of Safety-Trim, such as the time limited servo drive, or simplified pilot/co-pilot wiring.
-Bob Newman
TCW Technolgies
www.tcwtech.com
Posted: Thu Oct 25, 2007 1:30 pm Post subject: New product annoucement |
I wasn't suggesting that, I was suggesting using that switch with your
two-speed box (or two of the Matronix boxes and a relay) to provide the
multispeed capability at the pilot's fingertips in a single switch, rather
than using a separate switch actuated by the flaps or somesuch.
- Tom
dale1rv6(at)comcast.net Guest
Posted: Thu Oct 25, 2007 1:47 pm Post subject: New product annoucement |
I used a simple 2 position switch that connects a wire that by passes a
resistor that slows down my pitch trim. When switch is closed the resistor
is ineffective and I have fast trim. Now I have 2 speed trim, all I need.
(KISS)
Dale
RV6a 935 hrs
Bruce(at)glasair.org Guest
Posted: Thu Oct 25, 2007 1:53 pm Post subject: New product annoucement |
While your system is interesting, my elevator trim motor draws 2-3 amps, my
roll trim is under 1 amp but the elevator is not.
Bruce
www.Glasair.org
Posted: Thu Oct 25, 2007 2:01 pm Post subject: New product annoucement |
Oh, sorry I mis-understood. With the Safety-Trim two speed controller you only need a simple SPST switch to activate the two speeds. The switch just grounds the "two-speed input" wire or leaves it open. The safety-trim control box does the rest. The switch can easily be a simple manual switch on the instrument panel.
-thanks,
Bob Newman.
Posted: Thu Oct 25, 2007 2:26 pm Post subject: New product annoucement |
Bruce, can you provide me a brand /model # or any other info about your elevator trim servo. We have not yet run into that limitation before and like to fully understand it. If there's room to offer another product that drives a common higher current servo we'd like to look into it.
Bob Newman.
Posted: Thu Oct 25, 2007 3:23 pm Post subject: New product annoucement |
Sure, I'm aware it can be done simply, I've just been interested in the
possibility of a single-switch approach... I was curious if the idea had any
merit from a piloting point of view -- ergonomics, safety, etc. Maybe I'll
just have to buy one of your nice boxes and blaze that trail myself.
-Tom
Posted: Thu Oct 25, 2007 3:57 pm Post subject: New product annoucement |
Tom, I had not fully appreciated the concept you proposed with the 51MX series switch. But now I do. And the answer is yes! It will work exactly as you described. One pole of the switch would drive the "two-speed switch input" and the other pole of the 51MX would drive the respective trim inputs.
-Bob Newman
