Posted: Thu Oct 25, 2007 5:14 pm Post subject: 427JV Flying update |
Allright People!
here is the latest on 427JV"rivet". at 2950 rpm on my Jab 3300 we are getting at 2000 ft, 295 to 345 on CHTs, EGTs read 1290 to 1320 at 2950rpm. Speed at 2950 is 130 mph. at 3200 it picks up to 145 mph. and EGTs and CHTs go down further.
May change the needles on the bings, but hard pressed to do it based on the EMS numbers. FUN plane to fly!! At take off you punch to full throttle and at 70mph pegged I 1400FPM climb! that is on 20 gallons and 220 lb pilot, 20lbs luggage. In decent you trim for 70 mph on final an shy squeeks in smooooooth!
Juan Vega
427JV
dredmoody(at)cox.net Guest
Posted: Thu Oct 25, 2007 5:45 pm Post subject: 427JV Flying update |
Sounds llike a recipe for lots of fun Juan. May there be no end to it. Viva Rivet the Wonder Plane.
Dred
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Fri Oct 26, 2007 3:59 pm Post subject: Re: 427JV Flying update |
Congrats Juan! You give us all hope that eventually we will be able to share in the fun.
Just curious, are the speeds you're reporting taken from the airspeed indicator or are they true air speeds?
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Posted: Sat Oct 27, 2007 7:12 am Post subject: 427JV Flying update |
Taken from True airspeed as well as ground speed on GPS. it was a flat calm day in ambient temp a
Juan
