Deems Davis
Posted: Wed Oct 24, 2007 2:09 pm Post subject: Static ports |
I installed the Safeair static ports
(see Pics )
I've read/heard that the ports themselves need to project slightly
beyond the skin of the aircraft in order to function properly. These
project slightly, BUT VERY slightly.
1. Am I going to have a problem w/ accuracy in instruments?
2. Anybody flying with these have any experience?
3. If they are problematic? Is there something that can be done from the
outside of the a/c to remedy/fix or am I going to have to recruit and
elf to crawl into the tailcone for me?
It seems I recall John Cox posting some pics of a Cirus installation
where they actually had afixed a wedge shaped piece of metal just
forward of the port itself. Could a machined metal disc be affixed to
the outside of the skin over the existing port?
4. If replacement is in order what has experience led people
THANKS
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
billderou(at)yahoo.com Guest
Posted: Wed Oct 24, 2007 2:42 pm Post subject: Static ports |
The issue with the protruding height is not only the port configuration but the thickness of the paint. I smoothed the rivets holding the port in place, and did not locate a rivet in front of the port in-line with the airflow. Next, I stuck a round toothpick in the static port during painting. After painting the hole was carefully smoothed at the opening.
End result was no protrusion nor static source problems.
Bill DeRouchey
N939SB, flying
Deems Davis <deemsdavis(at)cox.net> wrote:
[quote]--> RV10-List message posted by: Deems Davis
(see Pics )
beyond the skin of the aircraft in [quote][b]
poneill(at)irealms.com Guest
Posted: Wed Oct 24, 2007 3:09 pm Post subject: Static ports |
That looks nearly identical to the Rivethead Aero static ports I installed:
http://www.noimnotcrazy.com/gallery/details.php?image_id=1870
I posted a similar question to the list a month or so ago, and several
people replied off list that the installation should work fine.
You'll be flying long before me so I can't help with the accuracy issue, but
I'll be eager to hear if you have any problems.
Best Regards,
Patrick #40715
AV8ORJWC
Posted: Wed Oct 24, 2007 5:44 pm Post subject: Static ports |
Two pictures, one was Dr. Carl Cadwell's IVP and the other was the new
Cirrus S-22, Generation 3 sitting on the restaurant grass in downtown
Oshkosh this summer.
Sidenote - Dr. Cadwell went on to build the first ever flying
experimental Epic which started the 51% controversy. He is living life
- Large and loving our right to build.
John #600
AirMike
Posted: Wed Oct 24, 2007 10:05 pm Post subject: Static ports - two sets? |
I was told that I should put an extra set (making 4) static ports with two dedicated to the TruTrak autopilot. My A&P friend told me to rig each set with the ports on each side of the tail cone and the connection fittings arching over the top of the tail cone. this arch prevents water from accumulating in the fittings.
_________________ See you OSH '18
Q/B - sold. |
Tim Olson
Posted: Thu Oct 25, 2007 3:06 am Post subject: Static ports |
One pair works fine. What you really want is ALTERNATE static in
the cockpit, as a pilot-controllable item. Your friend is
right about the tubing routing, however. An alternate static can
be installed many ways, but it's just a way of opening the static
line from inside the cockpit.
Tim
AirMike wrote:
-------- OSH '08 or Bust
http://forums.matronics.com/viewtopic.php?p=141648#141648
LloydDR(at)wernerco.com Guest
Posted: Thu Oct 25, 2007 4:46 am Post subject: Static ports |
I have them and do not see an error, but I also do not have paint yet.
Tim did find that if you have them installed and paint both the plane
and the ports at the same time they still protrude, I think the problem
arises when a thick layer of primer/paint is in place causing the port
to not protrude as much. I made sure there was no primer between the
mating surfaces, and all layers of primer and paint will be applied
evenly on the outside.
After paint I will do more testing and follow up with the results.
Dan
N289DT RV10E
John Ackerman
Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
Posted: Thu Oct 25, 2007 6:08 am Post subject: Static ports |
Does anybody have a source for a valve that will open the static
system (1/4" Tygothane plastic tubing in our case) to cabin air?
normal position would be "closed" of course, so that the static
system is only open to the static ports. Alternate position would be
open to the cabin OR to both the cabin and the static ports.
I'd like to mount one on the far right side of the panel, but can't
seem to track down a suitable valve.
Any leads will be greatly appreciated.
John and Marlys Ackerman
40458 "finishing"
On Oct 25, 2007, at 4:05 AM, Tim Olson wrote:
Tim
Tim Olson
Posted: Thu Oct 25, 2007 6:49 am Post subject: Static ports |
I used something very much like these:
http://www.valinonline.com/product.asp?prodid 733
You can get them with various fittings, bulkhead mount them,
and they seal well and open with plenty opening to work
well.
My Beech's specified location for it was on the trim panel
by the pilots Left knee, similar to just above where
some Pipers put a fuel valve on the sidewall. I used that
concept for my -10 and mounted it just forward of the air
vents near the top of that trim panel. The lever is mounted
pretty close to the sidewall and it would be hard to snag
it open. I know some people put them in the actual panel,
but there's really no need to be THAT accessible. You
do want it in a place you can easily reach to activate
if your static ports freeze up.
http://www.flightsimaviation.com/data/FARS/part_23-1325.html
You need a heated pitot tube (FAR 23.1323d) and an alternate static
source (FAR 23.1325 (b)(3)) for IFR flight. Wonder how many
people building an IFR aircraft are taking this into consideration...
Tim Olson - RV-10 N104CD
John Ackerman wrote:
Does anybody have a source for a valve that will open the static system
normal position would be "closed" of course, so that the static system
is only open to the static ports. Alternate position would be open to
I'd like to mount one on the far right side of the panel, but can't seem
40458 "finishing"
> Tim
37.03 KB |
627 Time(s) |
Tim Olson
Posted: Thu Oct 25, 2007 6:53 am Post subject: Static ports |
PS, search for "Toggle Valve".
40458 "finishing"
> Tim
GRANSCOTT(at)aol.com Guest
Posted: Thu Oct 25, 2007 6:56 am Post subject: Static ports |
In a message dated 10/25/2007 9:52:30 A.M. Central Daylight Time, Tim(at)MyRV10.com writes:
| Quote: | You need a heated pitot tube (FAR 23.1323d) and an alternate static
people building an IFR aircraft are taking this into consideration... |
Tim,
Hard to break the face plate on the VSI as an alternate static air if you have all glass!
Patrick
See what's ne [quote][b]
Posted: Thu Oct 25, 2007 7:04 am Post subject: Static ports |
Safeair has a nice add on kit
Dan N289DT
joe(at)mile-high-aviation Guest
Posted: Thu Oct 25, 2007 7:20 am Post subject: Static ports |
PLEASE CHECK OUT WWW.MILE-HIGH-AVIATION.COM FOR ALL YOUR PILOT AND AIRCRAFT
SUPPLY NEEDS. IF IT IS NOT LISTED I CAN ORDER IT.. NEW PRODUCTS LISTED EVERY
HOUR.
401-228-6677
Tim Olson
Posted: Thu Oct 25, 2007 7:31 am Post subject: Static ports |
Yeah, the EFIS changes things a bit. Not gonna do much good if you
smash your EFIS. Also, for backup instruments, a VSI is not
a commonly installed gauge. Yeah, it's got some useful info, and
as a primary instrument you'd definitely want one, but as a backup
separate instrument it's usually attitude, airspeed, TC, Compass,
and altimeter displayed in any number of ways.
I don't believe though that just because you CAN break the glass
on a VSI that it would be considered as having an appropriate
alternate static source.
GRANSCOTT(at)aol.com wrote:
| Quote: | In a message dated 10/25/2007 9:52:30 A.M. Central Daylight Time,
Tim,
you have all glass!
Patrick
rv(at)thelefflers.com Guest
Posted: Thu Oct 25, 2007 7:39 am Post subject: Static ports |
SafeAir has a solution that should work.
What's on my Cherokee is the same valve as the fuel drain.
Date: 2007/10/25 Thu AM 09:07:59 EST
Subject: Re: Re: Static ports
40458 "finishing"
> Tim
Deems Davis
Posted: Thu Oct 25, 2007 7:51 am Post subject: Static ports |
John, Safeair sells an alternate static port. It's a pretty simple
system. Just a plug that fits into a quick connect fitting also
available from MSC supply.
http://www.safeair1.com/index.htm
Deems Davis # 406
sam(at)fr8dog.net Guest
Posted: Thu Oct 25, 2007 8:11 am Post subject: Static ports |
I have the Cleveland static ports, they have a 6 to 8 kt error, directly
compared to others while formation flying.
Sam
rv(at)thelefflers.com wrote:
> From: John Ackerman <johnag5b(at)cableone.net>
> To: rv10-list(at)matronics.com
> 40458 "finishing"
>> Tim
>>> Read this topic online here:
wcurtis(at)nerv10.com Guest
Posted: Thu Oct 25, 2007 8:31 am Post subject: Static ports |
While this is an excellent idea and I try to model as much as I can on Type Certificated aircraft which fall under FAR Part 23, our experimental RVs fall under FAR Part 21. Now if this was mentioned under Part 91 (operations) that would be another story. Experimental OBAM are bound by FAR Parts 21 and 91. So while I'm sure we would also adhere to part 43 in maintenance of our OBAM, while 43.1 specifically excludes OBAM, it is probably still a good ides to follow the guidelines in 43.1.
William
http://wcurtis.nerv10.com/
Tim Olson
Qualify that a bit more though. Do you have the OLD Cleveland
ports with the flat face, or the NEW cleveland ports with the
domed face? The old ones had that amount of error, but I
see more like 2Kts with the new.
Sam Marlow wrote:
Sam
>> 40458 "finishing"
>>> Tim
Posted: Thu Oct 25, 2007 9:11 am Post subject: Static ports |
I have the new domed set. It helped, from the original flat units, they were about 15 to 20 kts off. So newer is better, but still not very close to accurate.
I saw Richard at OSH this year, and ask him about the error, he said the positioning was just a best guess, and you can put them anywhere if it works. He didn't have a problem on his 10, he though his was right on the money. Richard is the kind of guy you can talk to, to bad the people that answer the support line don't share this attribute.
Tim Olson wrote: [quote]--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com> (Tim(at)MyRV10.com)
Sam Marlow wrote:
| Quote: | --> RV10-List message posted by: Sam Marlow <sam(at)fr8dog.net> (sam(at)fr8dog.net)
I have the Cleveland static ports, they have a 6 to 8 kt error, directly compared to others while formation flying.
Sam
rv(at)thelefflers.com (rv(at)thelefflers.com) wrote:
| Quote: | --> RV10-List message posted by: <rv(at)thelefflers.com> (rv(at)thelefflers.com)
| Quote: | From: John Ackerman <johnag5b(at)cableone.net> (johnag5b(at)cableone.net)
--> RV10-List message posted by: John Ackerman <johnag5b(at)cableone.net> (johnag5b(at)cableone.net)
Does anybody have a source for a valve that will open the static system (1/4" Tygothane plastic tubing in our case) to cabin air?
normal position would be "closed" of course, so that the static system is only open to the static ports. Alternate position would be open to the cabin OR to both the cabin and the static ports.
I'd like to mount one on the far right side of the panel, but can't seem to track down a suitable valve.
40458 "finishing"
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com> (Tim(at)MyRV10.com)
Tim
AirMike wrote:
| Quote: | --> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net> (Mikeabel(at)Pacbell.net)
