VE3LVO(at)rac.ca Guest
Posted: Sun Feb 19, 2006 7:38 am Post subject: Check valve dimensions |
Cheers,
I am planning the "fuel pump board" for the rear baggage area
and it will be about 13-1/2"x9-1/2" and vertical. When I received my FWF
kit, it appeasr the company was in its agony throes and I didn't notice some
lacking parts, among which were the NRV (check valves) which are spec'd in
parallel with now-series pumps. Roger is very kindly sending these, but in
the interim, I want to plan the layout.
If your magic carpet is nearby, and you think of it, I would
very much appreciate a measurement of the overall length of your
Europa-issue check valves and/or the approximate length of the 'body' OAL
minus nipples. I presume the nipples to be 3/4" or 19mm each for 8mm
tubing.
Thank you in advance,
Ferg
A064
engine hung
Ivor Phillips
Posted: Sun Feb 19, 2006 9:25 am Post subject: Check valve dimensions |
Hi Ferg
Assuming that Europa give you the Andair CK321-H check valve, The
measurements are 72.80mm overall including nipples, Body only is 41.40mm,
the nipples are 8.20mm O/D, Diameter for the main body are 27.40mm
Ivor Phillips
g-iani(at)ntlworld.com Guest
Posted: Sun Feb 19, 2006 9:58 am Post subject: Check valve dimensions |
Ferg
The Andair check valves are 44.5mm between the ends of the pipe (when pushed
fully home)
I will send you direct a picture of the layout I used for Terry Clark G-IRON
if this helps
Ian Rickard #505 G-IANI XS Trigear
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
