jfrjr(at)adelphia.net Guest
Posted: Sat Oct 20, 2007 3:29 am Post subject: Camlocks question |
Just installed camlocks on both the firewall as well as the cowling sides. Fairly easy installation and with good directions. But I installed everything prior to priming/painting so how do I get the grommets off the cowling skins when I am ready to paint? Those grommets are held on with a small retention washer that is installed with a special tool (supplied with the kit). Is there another tool to remove the washer or do you sacrifice the washer each time you have to remove the grommett? Thanks for the help. Jay Rowe
[img]http://promos.hotbar.com/promos/promodll.dll?GetPromo&El=&SG=&RAND=40789&partner=seekmo&/p.gif[/img]
n223rv(at)wolflakeairport Guest
Posted: Sat Oct 20, 2007 3:53 am Post subject: Camlocks question |
If you are talking about the push nut, it is sacrificial. Push on, pry off..
-Mike
