Ground Tabs
ron.mcgann(at)baesystems.
PostPosted: Fri Oct 19, 2007 3:28 am    Post subject: Ground Tabs Reply with quote
G'day all,
For those that have completed the engine install, how many ground tabs are typically required on the engine side of the firewall? I have a 24 tab block on the cabin side and plan a smaller 10 tab block on the engine side - is 10 enough?
thanks in advance
Ron
187 finishing
[quote]"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
Albert Gardner
PostPosted: Fri Oct 19, 2007 4:30 am    Post subject: Ground Tabs Reply with quote
I used only 1 tab on the engine side of the firewall. That one was for the oil pressure switch that connected the Hobbs meter to ground.
Albert Gardner
Yuma, AZ
N991RV
RV-9A N872RV
RV-10 N991RV
Tim Olson
PostPosted: Fri Oct 19, 2007 4:52 am    Post subject: Ground Tabs Reply with quote
Ron,
For a Lyc install, 10 is even way more than you need for the
smaller ground wires. You'll have almost nothing. You
will, however, want to make sure you have a good engine
and engine mount ground strap.
McGANN, Ron wrote:
G'day all,
thanks in advance
Ron
187 finishing
"Warning:
your computer."
jesse(at)saintaviation.co
PostPosted: Fri Oct 19, 2007 5:03 am    Post subject: Ground Tabs Reply with quote
On the engine side I just have the one big ground from the engine to the airframe. I don’t ground anything else on the front side. The 24 tab block should probably cover it on the cabin side.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: McGANN, Ron [mailto:ron.mcgann(at)baesystems.com]
Sent: Friday, October 19, 2007 6:27 AM
Subject: Ground Tabs
G'day all,
thanks in advance
Ron
187 finishing [quote]"Warning:The information contained in this email and any attached files isconfidential to BAE Systems Australia. If you are not the intendedrecipient, any use, disclosure or copying of this email or anyattachments is expressly prohibited. If you have received this emailin error, please notify us immediately. VIRUS: Every care has beentaken to ensure this email and its attachments are virus free,however, any loss or damage incurred in using this email is not thesender's responsibility. It is your responsibility to ensure viruschecks are completed before installing any data sent in this email toyour computer." [b]
Tim Olson
PostPosted: Fri Oct 19, 2007 5:26 am    Post subject: Ground Tabs Reply with quote
On the inside of the cabin, it will depend greatly on how much
you try to pull grounds back for all circuits to use the
single-point ground to prevent ground issues. I filled up
about 48 or more tabs on mine. I think the strip from B&C
was about 5" long or so. It won't hurt to buy oversized on the
ground tab block if you have room for it.
Jesse Saint
jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>
www.saintaviation.com <http://www.saintaviation.com>
Cell: 352-427-0285
Fax: 815-377-3694
*From:* McGANN, Ron [mailto:ron.mcgann(at)baesystems.com]
*Sent:* Friday, October 19, 2007 6:27 AM
*To:* rv10-list(at)matronics.com
*Subject:* Ground Tabs
G'day all,
thanks in advance
Ron
187 finishing
bcondrey
PostPosted: Fri Oct 19, 2007 7:03 am    Post subject: Ground Tabs Reply with quote
Ron,
One more data point for you – I just looked and am using 5 tabs on the engine side of the FW and can’t imagine using more. Here’s the list: Oil Temp sensor, Fuel Pressure sensor, 2 hall effect current sensors (dual electrical bus and I’m monitoring total current draw from each alternator, and finally 1 for an old fashioned Oil Pressure switch like you’d use for a hobbs (drives an oil pressure light – I have my EIS remotely mounted and have all alerting via the EFIS so this is a backup).
I’m using a GRT EIS if it makes a difference. Grounding sensors on the cabin side wouldn’t be a big deal if you wanted to totally avoid the connections on the engine side – just more wire to run.
Bob #40105
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGann, Ron (AUS BAeA)
G'day all,
thanks in advance
Ron
187 finishing
"Warning:The information contained in this email and any attached files isconfidential to BAE Systems Australia. If you are not the intendedrecipient, any use, disclosure or copying of this email or anyattachments is expressly prohibited. If you have received this emailin error, please notify us immediately. VIRUS: Every care has beentaken to ensure this email and its attachments are virus free,however, any loss or damage incurred in using this email is not thesender's responsibility. It is your responsibility to ensure viruschecks are completed before installing any data sent in this email toThe information contained in this email and any attached files is
5
6
7
8
9
5
6
lessdragprod(at)aol.com
PostPosted: Fri Oct 19, 2007 7:15 am    Post subject: Ground Tabs Reply with quote
Just a point of clarification. (However, this does go back a few years to what I think I remember.)
A single ground point refers to the same electrical ground potential, rather than physically the same point.
Having a 24 tab block on the firewall back to back with a 10 tab block on the engine side of the firewall should be both.
Not having ground wires go through the firewall sounds like a good thing. However, the tab connections are more subject to the elements (corrosion) on the front side of the firewall and should be protected accordingly.
Jim Ayers
Bill Schlatterer
PostPosted: Fri Oct 19, 2007 4:50 pm    Post subject: Ground Tabs Reply with quote
Could also have grounds for P-Mags and E-Mags that might go to the FW instead of engine? Why not just put the small B&C block on the other side (FW side) of the internal (Cabin side) big block and have plenty? BUT 10 should be plenty!
Bill 7a Ark
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA)
Sent: Friday, October 19, 2007 10:03 AM
Subject: RE: Ground Tabs
Ron,
Bob #40105
G'day all,
thanks in advance
Ron
187 finishing
5
6
7
8
9
5
6
7 [quote][b]
PostPosted: Fri Oct 19, 2007 11:43 pm    Post subject: Ground Tabs Reply with quote
Thanks for all the responses guys. I have no shortage of ground tabs inside the cabin, the 24 tab block is connected to a couple of 25 pin dsubs ganged together and connected ala Nuckolls. I'll go with the 10 tab block on the engine side.
Jim - what do you use for corrosion protection of the engine side block??
cheers,
Ron
