Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Sat Oct 20, 2007 6:28 am Post subject: Autopilot functions |
I am trying to select an appropriate autopilot for what I want to do with it. I will be using a G530W and an SL30 Nav/Com as some of my avionics, as well as the new high res GRT EFIS. With these components driving the autopilot is it possible to fly a coupled VOR/ILS/LOC approach using a Digiflight II VGSV or do I need to get one of the higher level autopilots to fly coupled Navaid based approaches? Not sure how to interpret what I see on tru-track's website and I haven't been able to call due to a very busy work schedule so I will defer to the experience and knowledge of the group.
Eric Kallio
40518 Baggage door and panel bewilderment
coop85(at)cableone.net Guest
Posted: Sat Oct 20, 2007 3:44 pm Post subject: Autopilot functions |
Eric,
I have the Digiflight II VGSV along with a Garmin 480, SL-30 along with
the GRT Dual EFIS. The system works great on all types of approaches -
VOR/ILS/GPS. My opinion is your setup will be the most bang for the buck.
I have the 480 driving the EFIS which then drives the autopilot. You can
also drive the autopilot directly from the 480 and it was recommended to me
to have a switch to select between the sources which I haven't tried yet.
Marcus
