daberti(at)sbcglobal.net Guest
Posted: Mon Oct 15, 2007 8:43 pm Post subject: Garmin GI106 |
I upgraded my 430 to a 430W and now my GI106 has a 6 degree error indicated by the start up test page. How do you realign it with the 430?
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Ray.R.Doerr(at)sprint.com Guest
Posted: Tue Oct 16, 2007 5:55 am Post subject: Garmin GI106 |
Go into the config menu by holding the Enter key while turning on the power. Then go to the menu where you calibrate the CDI by setting it to 150 degrees and then hit enter. That should do it. I had the same issue when I got both of mine upgraded to WAAS.
Thank You
Ray Doerr
From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Dave
Sent: Monday, October 15, 2007 11:42 PM
To: avionics-list(at)matronics.com
Subject: Garmin GI106
| Quote: | | http://www.matronics.com/Navigator?Avionics-List | 01234
reichec
Posted: Tue Oct 16, 2007 2:38 pm Post subject: Garmin GI106 |
there is a cal to 150 degrees option in the setup mode
this is best done at full voltage(engine running)
Charles Reiche
Posted: Tue Oct 16, 2007 3:44 pm Post subject: Garmin GI106 |
Thanks for the replies! Constantly being off that much was was a real pain!
Dave
[quote] --
