"belly" dragger
Thom Riddle
PostPosted: Sat Oct 13, 2007 12:17 pm    Post subject: "belly" dragger Reply with quote
NOT KOLB RELATED
While looking at Standard Category airplanes that fit the LSA category, I ran across this oddball. I don't think many were made because I've never seen one or heard of one before. It is legitimate because it is listed on page 9 of the Type Certificate Data Sheet for Aeronca Champ series (TCDC A-759). Photo of this Aeronca 7JC w/ C-90 engine is attached. Weird! As it turns out, it is NOT LSA compliant because it has a gross weight of 1,450 lb.
 Filesize:  19.45 KB
 Viewed:  506 Time(s)
Aeronca Champ TCDS A-759.pdf
Download
 Filename:  Aeronca Champ TCDS A-759.pdf
 Filesize:  479.7 KB
 Downloaded:  767 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
jb92563
PostPosted: Tue Oct 16, 2007 12:19 pm    Post subject: Re: "belly" dragger Reply with quote
I'll bet that would turn on a dime.
Ground loop prone perhaps as well in stiff x-winds.
Its more of a backwards tricycle gear kindof rather than a tail dragger.
I though with this threads title it was going to be about us beer drinking Kolbers.... Wink
Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
