CardinalNSB(at)aol.com Guest
Posted: Fri Oct 12, 2007 6:33 am Post subject: el cheapo battery tester |
I coldn't resist the $16 battery tester on sale at Harbor Freight, for 12 volt batteries, it says for CCA up to 1000 amps and is rated at 100 amps.
Will this cause harm to "regular car batteries, flooded wet cells", and to Odyssey type sla batteries?
The security shop next door throws out batteries all the time, out of about 20 I got out of the trash over the years 2 have held voltage overnight, but I have never relied on them for anything.
What is the best way to use this product to test both types of batteries, or should I go get my money back?
Thanks, Skip
See what [quote][b]
nuckolls.bob(at)cox.net Guest
Posted: Fri Oct 12, 2007 7:37 am Post subject: el cheapo battery tester |
At 10:31 AM 10/12/2007 -0400, you wrote:
| Quote: | I coldn't resist the $16 battery tester on sale at Harbor Freight, for 12
Thanks, Skip
The tester you have has some utility. In spite of the
claims as to what it's capable of doing, the simplest
description of functionality says it will put a signifiant
load (50+ amps) on a battery to demonstrate it's ability
to carry a load. I suspect it's similar to this device:
http://www.aeroelectric.com/Pictures/Tools/Battery_Testers/HF_Resistor_Load.jpg
While more portable and convenient than hooking the
battery to your car and measuring terminal voltage while
cranking, the fixed resistor tester is a simple, gross
look at a battery's performance but not very quantitative.
The next step up is a tester like this:
http://www.aeroelectric.com/Pictures/Tools/Battery_Testers/HF_Carbon_Pile_Load.jpg
Here the goal is to put as much load on the battery as it
will tolerate while holding terminal voltage at the bottom
of the green arc appropriate to the battery's temperature.
There's a timer and buzzer in the tester that starts
when you crank up the current.
http://www.aeroelectric.com/Pictures/Tools/Battery_Testers/HF91129_2.jpg
When the buzzer goes off at 15 seconds, read the current
that the battery will support at the voltage appropriate
to the temperature. This is a MEASURE of that battery's
ability to crank an engine.
CAPACITY is another matter entirely. To make this determination,
you need to deplete and measure the energy the battery will
deliver at a load current of interest (like your e-bus loads).
This takes a device like:
http://www.aeroelectric.com/Pictures/Tools/Battery_Testers/CBA2_1.jpg
To make a learned decision as to the suitability of
any battery to do a task, you should consider both
short term high current, low-energy loads and long
term, low current, high-energy loads.
The tester you have is a good value but it's limited.
It does not tell you everything you'd really like to know
about any given battery.
( "Problems are the price of progress. )
( Don't bring me anything but trouble. )
( Good news weakens me." )
( -Charles F. Kettering- )
