3edcft6(at)cox.net Guest
Posted: Tue Oct 09, 2007 12:51 pm Post subject: VHB Tape vs Rivets |
I have recently seen an episode of "Modern Marvels" on the history
channel called "Sticky Stuff". One of the things they had on that show,
is this tape called VHB tape made by 3M. In a test they repeatedly
impacted a 16 lb bowling ball against 2 sheets of aluminum bonded with
VHB tape till it failed, then they did the same test with the 2 sheets
of aluminum riveted together. Since this was 3M doing the test,
obviously there tape performed better. However based on the fact that
bowling balls are between 8.5 and 8.6" in diameter, it appears as they
only had a rivet every 4 inches. I would be really curious to see how
the tape compared to doing it with the appropriate number of rivets.
Anyone want to try the test? Below is a link to a youtube video of the
demonstration.
http://youtube.com/watch?v=ZhKreIqU_R4
Chris W
KE5GIX
"Protect your digital freedom and privacy, eliminate DRM,
learn more at http://www.defectivebydesign.org/what_is_drm"
Dave(at)AirCraftersLLC.co Guest
Posted: Wed Oct 10, 2007 3:46 pm Post subject: VHB Tape vs Rivets |
I've been told first hand by an experienced RV4 builder in California that
he used VHB tape to stick the stiffeners to the inside of his elevators. He
had prior experience with it and has flown it many hours since. No
problems.
We use it here and there for non-structural items and it works great, but I
have not done long-term testing.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
