acepilot(at)bloomer.net Guest
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Bob Collins
mike109g6(at)insideconnec Guest
Posted: Sun Sep 30, 2007 7:36 pm Post subject: HVLP Questions |
Bob,
All I use any more is HVLP. It's the BOMB! Less, way less, overspray, and
using a lot less material-saves$$$$$.
1) any good single stage or 2 stage air compressor will work. Any brand. I
would suggest that if you have space and $ invest in a good stand up
compressor. Sears is ok but over priced. If you have a Tractor Supply Co.
near look there. If not any good discount place, home depot, Lowe's will
have 30-80 gallon size. CFM is the number that you are looking for on the
compressor. Higher the better. My IR is 80 gallon single stage 18.1CFM
5HP - works like a mule. It will also keep up with ANY air tool that you
have, die grinder, cut off tool, sanders, NOTHING can bog it down.
2) Invest in a good quality HVLP gun. It makes all the difference in the
world. DeVilbiss is all that I use. AKZO epoxy primer, basecoat,
clearcoat, will handle it all. Gravity fed(cup on top) or pot feed is the
only way to go. Got mine on Ebay, new, half price what I could get it for
locally. On Ebay search HVLP paint gun, Devilbiss, there are quite a few
west coast reputable companies out there that have tons of stuff and great
price. Like with anything - SHOP till you drop before laying out the $ .
You'll get a better product for your bucks.
3). I picked up the digital level/laser also-mine was craftsman's club no
brainer. check out there 3D laser level with stands for $40 when on sale.
Very easy to stripe an a/c the entire length on both sides with two, or to
do checkerboard on cowl/spinner/rudder.
Hope that this all helped,
PS - MUST have an inline water trap/filter with any compressor, big or
small, compressed air makes water and will ruin your tools and paint. You
are right-no inline oiler.
Mike H 9A, 8A
Posted: Mon Oct 01, 2007 2:47 am Post subject: HVLP Questions |
Sounds like good advice. I'll shop around...
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
mike humphrey wrote:
<mike109g6(at)insideconnect.net>
Bob,
overspray, and using a lot less material-saves$$$$$.
brand. I would suggest that if you have space and $ invest in a good
stand up compressor. Sears is ok but over priced. If you have a
Tractor Supply Co. near look there. If not any good discount place,
home depot, Lowe's will have 30-80 gallon size. CFM is the number
that you are looking for on the compressor. Higher the better. My IR
is 80 gallon single stage 18.1CFM 5HP - works like a mule. It will
also keep up with ANY air tool that you have, die grinder, cut off
the world. DeVilbiss is all that I use. AKZO epoxy primer, basecoat,
the only way to go. Got mine on Ebay, new, half price what I could
get it for locally. On Ebay search HVLP paint gun, Devilbiss, there
are quite a few west coast reputable companies out there that have
tons of stuff and great price. Like with anything - SHOP till you
drop before laying out the $ . You'll get a better product for your
bucks.
club no brainer. check out there 3D laser level with stands for $40
when on sale. Very easy to stripe an a/c the entire length on both
sides with two, or to do checkerboard on cowl/spinner/rudder.
You are right-no inline oiler.
Mike H 9A, 8A
Posted: Mon Oct 01, 2007 9:10 pm Post subject: HVLP Questions |
Scott,
Glad that I could help out. One thing that is Critical to the life of any
HVLP gun is to clean it immediately after use. I buy 5 gal cans of lacquer
thinner at a discount paint shop/auto body shop and run 3x 1/2 cups of
lacquer thinner through it after each use. Thoroughly wipe out the cup with
a clean paper towel soaked in lacquer thinner and the nozzle. Let it air
dry before putting it away. If you maintain your equipment, it will last
forever. I have one HVLP gun that is 3 years old and shoots as good as day
one. The outside ain't so pretty but the guts are spotless. Most people
don't take care of their guns properly and then cuss them when they fail.
Also you can plumb your shop with HIGH pressure PVC pipe and not cast iron,
same isle as the regular PVC water pipe, just look for High Pressure
HOT/COLD on the PVC. Regular or High PVC cement.
Good luck,
Mike H 9A, 8A
rvbuilder(at)sausen.net Guest
Posted: Wed Oct 03, 2007 12:46 am Post subject: HVLP Questions |
If you use PVC, I would make sure your compressor is shut off after every use. Good practice either way. PVC will work but it will also become brittle over time and can shatter with a solid hit from something. If it's permanent, use type L copper pipe. It's more expensive but will last forever. It's also rated for compressed air.
Michael Sausen
Rv-10
Posted: Wed Oct 03, 2007 2:42 am Post subject: HVLP Questions |
All good advice. I have no plans to plumb my shop with air though. I
just drag the air hose around to where I need it...
Scott
RV Builder (Michael Sausen) wrote:
Michael Sausen
Rv-10
n616tb(at)btsapps.com Guest
Posted: Wed Oct 03, 2007 6:00 am Post subject: HVLP Questions |
My last shop was plumbed with high pressure pvc pipe and I did have a blow
out. I was in the shop when it happened and it took a few years off my
life. Shrapnel was everywhere and damaged a couple of things but nothing
major. If anyone wants to plumb the shop I would recommend this product:
http://nibco.com/cms.do?id &pId=14
It is PVC and rated for compressed air. It isn't quite as cheap as regular
o'l pvc but still not bad and glues together the same. It is green and they
have great fittings for doing air. I used it and had T fittings pointing up
for each drop. Then they have a 180 degree short bend that allows you to go
from the T fitting down to your coupling. This is great because any water
in your pipe is not dropped to your fittings but rather continues down the
run to the end where you can place a separator.
Good stuff and much safer.
[quote] --
Posted: Wed Oct 03, 2007 6:34 am Post subject: HVLP Questions |
Just for clarification, this stuff looks to be ABS and not PVC.
Michael
Posted: Wed Oct 03, 2007 6:42 am Post subject: HVLP Questions |
Right you are as I didn't realize the difference. I generalized. oops!
[quote] --
