Wire specifications
Goto page 1, 2  Next
jpx(at)qenesis.com
PostPosted: Tue Oct 02, 2007 2:37 pm    Post subject: Wire specifications Reply with quote
I am building a Dream Aircraft Tundra (4 place aluminum bushplane) and
am confused as to what wire to buy.
Most wire comparisons list TKT as being the only thing that is wonderful.
However, most companies seem to be selling Tefzel for homebuilt aircraft.
Is there a convenient source of reasonable lengths of TKT wire ?
Thanks !
Jeff Page
Tundra #10
nuckolls.bob(at)cox.net
PostPosted: Tue Oct 02, 2007 7:05 pm    Post subject: Wire specifications Reply with quote
Why do you want TKT? M22759 Tefzel has been the wire
of choice in Wichita for tens of thousands of airplanes
for about 25 years.
( "Problems are the price of progress. )
( Don't bring me anything but trouble. )
( Good news weakens me." )
( -Charles F. Kettering- )
JOE RONCO
PostPosted: Tue Oct 02, 2007 7:46 pm    Post subject: Wire specifications Reply with quote
BOB: I don't know anything about aircraft wire but in surfing the net I
found this link. Comments?
http://www.vision.net.au/%7Eapaterson/aviation/wire_types.htm
Joe R
tonybabb(at)alejandra.net
PostPosted: Tue Oct 02, 2007 11:32 pm    Post subject: Wire specifications Reply with quote
In surfing the web some I found this
http://etd-submit.etsu.edu/etd/theses/available/etd-0714104-142243/unrestric
ted/KiptinessS080904f.pdf
On page 100 it seems to say that TKT and Mil Spec 22759 are equivalent.
Usual disclaimers - I'm electrically challenged etc.
Tony
PostPosted: Wed Oct 03, 2007 7:25 am    Post subject: Wire specifications Reply with quote
Subject: RE: Wire specifications
Joe R
Oh yeah, THAT link.
Discussing wire types is taking a drink from the
firehose. There are as many recipes as there are
chefs . . . each having the fondest wish that
his/her dish becomes the worldwide favorite.
Then there are wires designed for specific
applications for industry or aerospace intended
for use in situations we'll never see on our
airplanes . . . nor could we afford to buy the
wire even if we wanted it.
I took the FAA to task some years ago about
the extensive list of "suggested and/or semi
approved" wire materials in AC43.13. Obviously
intended to aid technicians and mechanics in the
field. While the data presented in the tables
(and in the link you cited above) are mostly
correct factually, it's like asking someone
for whom English is a second language to
do the assembly manual for a tricycle and
then suggesting that the 10-volume set Oxford
dictionary would be a good resource. . .
The majority of wired types suggested in AC43-13 would
be hard for ME to get and I do business with the world's
premier suppliers of the stuff. To offer that 'comprehensive'
list was a waste of both the writer's and the reader's time. Of
course the writer was on the taxpayer's payroll.
Allow me to suggest that M22759 Tefzel from the popular
suppliers to the OBAM aircraft industry is the finest
wire we've used in GA aircraft to date, is widely available
and reasonably priced. Praying over the Concise Dictionary
for Wire is probably not a good use of your time beyond
expanding your intellectual horizons on the universe of
wire types.
 Filesize:  128.54 KB
 Viewed:  817 Time(s)
JOE RONCO
PostPosted: Wed Oct 03, 2007 8:45 am    Post subject: Wire specifications Reply with quote
Thanks Bob. I now get the picture (I think) and won't spend any more
time on this topic.
Joe R
mprather(at)spro.net
PostPosted: Wed Oct 03, 2007 8:47 am    Post subject: Wire specifications Reply with quote
Bob,
Would you also say that it's at least as important to install wire
correctly as it is to choose the correct insulation material? Certainly
many would say PVC insulation is evil and its use is suicidal/homicidal,
but a good many airplanes will (have) go(ne) to the bone yard with big
bundles of it, not because of wiring safety but because of airframe
fatigue life.. To me that says that it's possible to use wire with PVC
insulation, but today the incremental cost associated with upgrading to
Tefzel is low enough that it's worth the benefits of more robust
mechanicals.
Matt-
>Joe R
Oh yeah, THAT link.
wire types.
frank.hinde(at)hp.com
PostPosted: Wed Oct 03, 2007 9:11 am    Post subject: Wire specifications Reply with quote
If you have ever (Like I have) had a wire short out behind the
instrument panel in your car that was not fused properly you will
certainly avoid PVC like the plague.
The rate the fire burns everything up and the thick accrid smoke it
produces would make such an event in an airplane life threatening!
Don't even think about it!
Frank
echristley(at)nc.rr.com
PostPosted: Wed Oct 03, 2007 9:39 am    Post subject: Wire specifications Reply with quote
Joe R
Wow! There's only ONE type of wire that is known to be safe. All of
those planes flying millions of miles year in and year out are just
ticking time-bombs, waiting for a wire to explode and send them crashing
into the seas. Luckily, there's someone with demonstrable proof of all
the danger we've faced for the last 4 decades.
PostPosted: Wed Oct 03, 2007 9:52 am    Post subject: Wire specifications Reply with quote
Matt Prather wrote:
Bob,
mechanicals.
Hear! Hear!
Call up Wiremasters. The sell in bulk and don't mind homebuilders.
I don't have their number or my receipt handy, but I think it was about
$150 I spent. I got enough spools of multi-colored, tinned-copper
Tefzel to wire my whole airplane and have enough left over to do most of
the next. I may have been able to find quality PVC for less, but I
would probably had to go surplus. I bought 100' spools of 22AWG (red,
green, white, black), 20AWG (red, green, white, black), 18AWG (red,
green, white, black), 16AWG(white), 12AWG(white). I also got 50' spools
of 8AWG(white) and 4AWG(white). That covers everything but the battery
cable, which I covered with welding cable.
The multi-color isn't an absolute need, but is nice to have. It cuts
down on some of the labeling requirements, especially when bundles of
related wires are twisted. Just chuck one end in the drill, pinch the
other end and squeeze the trigger until the bundles starts shrinking.
For instance, the magnetometer connects to the Dynon EFIS with a power,
ground and two signal lines. Red, black, white and green (respectively)
and it doesn't really need a label at all; though it does get a big
"magnetometer" sticker for good measure.
The rack of wire is incredibly useful when the time comes. Just run the
wires and not worry about estimating how much of each is needed. It's a
good item for a builder group to have. Pay for what you use, and then
pass it on to the next guy. Reload with a multi-hundred foot spool when
one runs out.
khorton01(at)rogers.com
PostPosted: Wed Oct 03, 2007 10:45 am    Post subject: Wire specifications Reply with quote
A coworker had an electrical fire behind the dash of his BMW. The smoke was so thick and acrid that he was unable to keep his eyes open. Fortunately it occurred immediately after start while the car was stopped. He turned off the key, opened the door, rolled out onto the ground and crawled away. He was very, very glad he was not moving when this occurred, because he is convinced he would not have been able to see to control the car.
Kevin Horton
On Wed, 3 Oct 2007 17:08:02 -0000
Frank
PostPosted: Wed Oct 03, 2007 11:23 am    Post subject: Wire specifications Reply with quote
Danged BMW's and their electrical problems! Being a former BMW owner, I
can attest to the fact that their electrical systems were not built to
Aeroelectric standards... Smile While I loved the way my '96 328i drove -
economy, handling, speed (when it ran properly), I finally got disgusted
with the string of expensive to fix issues the car had.
At least if your friend had been rolling down the road when the failure
occurred, there would have been airflow available to evacuate the smoke.
Matt-
<khorton01(at)rogers.com>
control the car.
Kevin Horton
> Frank
cnpeters
PostPosted: Thu Oct 04, 2007 6:01 pm    Post subject: Re: Wire specifications Reply with quote
Bob (and anyone else who has wire length data for their RV),
So you had more than enough ordering 100 feet of each color and gauge you mention below, or were these multi 100' spools?
If I was to simplify the number of gauges to keep in stock, what would you recommend? Aside from some situations (alternator, etc), would 18 and 22G cover a typical RV?
I ask, as I am getting ready to place an order and want to try and cover the whole project (RV-9A, Dynon glass EMS/EFIS, setup for VFR day and night).
Carl
[/quote]
one runs out.[/quote]
Carl Peters
RV-9A wings
stein(at)steinair.com
PostPosted: Thu Oct 04, 2007 6:57 pm    Post subject: Wire specifications Reply with quote
That's an awfull lot of some of the wire, but probably tight on a few
others. Couple of suggestions:
All power wires red (down to about AWG14 which is the largest size most
people stock in colors), Ground wires black, lighting wires yellow, signal
wires white, etc... Pick a scheme and stick with it. In our shop we pretty
much do that as standard practice.
Also 50' of AWG8?!?! Normally on an a 2 seat RV you'd see about 4-6' total!
AWG20 you'll hardly use at all outside of the panel, and then the amount can
vary dramatically depending on what you wire. AWG16 is also something you
may use a lot of or use almost none of...depending on equipment...same with
AWG14. AWG18 and AWG22 are the big ones!
The suggestion presented previously about twisting the Dynon wires brings up
another point....SHIELDED WIRES! Most of the EFIS's with remote mag's
recommend them to be shielded (especially Dynon). If you're going to
install a dynon or AFS unit it would be wise to use shielded wire now while
you can instead of trying to fix the gremlins later.
Same goes with audio wiring. The jacks, radio, intercom, etc.. should be
wired with shielded wire, and lots of avionics also require shielded wire.
I'm a fan of people buying lots of wire Smile, but the best approach is to
conceptually decide what is going to be in the plane (lighting, avioincs,
engine, batteries) and then decide. Your requirements may vary by literally
many hundreds of feet just by the avionics alone. Also, if you don't wire
up your own panel, then you'll need much less wire.
I hate to tell you this, but no matter how much stuff you buy up front in
your initial shotgun blast, you'll still likely be left needing something
you forgot....it's just part of building - UPS loves it!
Just my 2 cents as usual
Stein
PS, excuse the typos...I'm still typing with one hand.
jpx(at)qenesis.com
PostPosted: Thu Oct 04, 2007 7:54 pm    Post subject: Wire specifications Reply with quote
Ok, Tefzel wire it is. Wire Masters and Stein both appear to have
useful information on their web sites and will probably ship to
Canada. Thanks.
Looking under the instrument panel of my 1970 Cessna 172, I had
believed that all aircraft wire was white. Of course this has made it
extremely difficult to follow a particular wire somewhere.
I had planned to use a little spray paint to identify wires, but
looking at the web sites, the Tefzel wire is available in a nice
rainbow of colors.
So should I purchase a variety of colours and end up with too much of
some colors and not enough of others, or should I stick with my
original plan and buy white and spray tracer colors on it ?
If so, how would I determine that the paint would not degrade the
insulation over time ?
Thanks again ! Jeff Page
of Wire is probably not a good use of your time beyond
wire types.
klehman(at)albedo.net
PostPosted: Fri Oct 05, 2007 1:37 am    Post subject: Wire specifications Reply with quote
Despite what they said, Wiremasters shipped UPS instead of USPS to me
though which added another $50.+ brokerage etc.... Probalby cause they
put the wire on spools and used a huge box to ship. OTOH their price on
RG400 was excellant.
You can use up a 100' roll pretty quick just running out to nav lights
and wingtip strobe power supplies. 95% of my wire is #18 or #22.
Ken
Canada. Thanks.
snip
longg(at)pjm.com
PostPosted: Fri Oct 05, 2007 5:05 am    Post subject: Wire specifications Reply with quote
Jeff,
I like your strategy, mix it up a bit. I'm doing the same as I am sick
of white or in the real oldies, fabric mixed in between. Asking about
preference in color on this board is akin to asking what type of ice
cream everyone likes Smile Logically I like the concept of associating
color with function. GPS is blue, com is orange, audio is green, ground
is black etc. Everyone will have their own preference. What works best
for you is what makes for good logic in your mind. Even if you follow
well thought out color patterns, some good labeling is always helpful.
Of course documenting your work will help you a year from now when the
colors all blend together.
BTW - Does anyone know where I can get one of those deals (I don't know
what they're called) the shops use to label the nice yellow shrink
covers they put on the ends of their connections?
MauleDriver(at)nc.rr.com
PostPosted: Fri Oct 05, 2007 5:20 am    Post subject: Wire specifications Reply with quote
I'm using the labeling method Bob suggests clear shrink tubing and
computer printed labels. Keeping a wire list in Excel or something that
lists the labels should make future maintenance easier - especially if
it falls to someone else.
Anyway, I just started but it seems to work. B&C sells a labeling 'kit'
with the needed sizes and amounts of clear shrink tubing. Cheap and easy.
Bill "running first wires in the RV10 project" Watson
rainbow of colors.
PostPosted: Fri Oct 05, 2007 7:16 am    Post subject: Wire specifications Reply with quote
Carl
Barring any last minute changes, I've completed the wiring on my Delta,
aft of the firewall. Here is what my wire rack look like now:
http://ernest.isa-geek.org/Delta/Pictures/WireRack.jpg
I bought 100ft of everything except the RG-400, 8AWG and 4AWG. I got
50ft of each of those. The 8 and 4 was bought seperately, but the total
of everything else was $162.
Contact information:
Deb Sullivan
dsullivan(at)wiremasters.net
1-800-635-5342
www.wiremasters.net
They specialize in aviation and military wire, so you don't have to
describe your project as an off-road vehicle like I do everywhere else.
PostPosted: Fri Oct 05, 2007 7:37 am    Post subject: Wire specifications Reply with quote
Point well taken. My orginal (and standing) goal was to put together a
communal kit that all the builders in my chapter could use. 100ft of
everything was just a feel-good number for a first attempt. If I were
to do it again, I'd buy much more of the 22AWG and much less of the
thicker wires. I'll need to order more of those for the next builder,
but I'll have the thick stuff for a long time. Of course, at
WireMaster's prices it doesn't hurt so much to have all that extra stuff.
I made up a spreadsheet that calculated the wire loss for each size I
bought. Inputs were the load and total wire length. The loss value
turns red when it is greater than 5%. Yellow when it's between 3 and
5%. I stayed away from the yellow, and there was practically no call
for 16AWG or thicker (though, I did oversize a few for motors). One
thing I've done is to use LEDs for practically all the lighting, so that
cuts down on some of the big wires.
I should have bought a roll or two of 22AWG shielded cable.
Goto page 1, 2  Next
Page 1 of 2
