john(at)leptron.com Guest
Posted: Mon Oct 01, 2007 11:08 am Post subject: tail wheels |
Hi guys,
I have been flying a grove aluminum tail spring for 8 years. Has any body been talking about them, has there been a problem you know of?
John Oakley
Speedster 4 long and short
912ul cap
Fox5flyer Guest
Posted: Mon Oct 01, 2007 4:12 pm Post subject: tail wheels |
John, I also have the Grove aluminum tailwheel spring on my S5 since May 2000. At first I installed the S5 spring, but found it was too stiff so Robby Grove swapped me for the S4 spring even after I'd drilled it. It is still a bit stiff, but does a good job combined with my Maule Tundra pneumatic tailwheel. About 95 percent of my operations are off of rough fields and it has held up well so far. I do recall one failure though. As I recall the spring broke near the bend and I think that the failure was caused by excessive side-to-side movement, but don't quote me on that. It was several years ago. I wasn't aware that Grove was no longer supplying those springs. Too bad.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 365+ TT
Posted: Mon Oct 01, 2007 5:10 pm Post subject: tail wheels |
Deke,
Thanks for the return. There seem to be a handful of us that are using the grove tail spring. All the talk about 3 spring systems has made a few of us edgy. I only knew of one failure and it was on an RV. Just checking, I did use a rubber pad under mine so it would not rub on the metal edge of the mount, I believe that was what caused the RV problem.
Thanks again.
john
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of fox5flyer
Sent: Monday, October 01, 2007 7:09 PM
Subject: tail wheels
Deke Morisse
Mikado Michigan
avtar412
Posted: Fri Oct 05, 2007 1:01 pm Post subject: Re: tail wheels |
Yes John, I have a grove aluminum tail spring and seems fine. I have mounted mine in a nylon block as I read that some past failure was due to stress cracking caused by the spring rubbing on a mounting bolt. See http://www.sportflight.com/cgi-bin/uploader.pl?action=view&epoch=1072508647 for pictures. John A.
60.39 KB |
669 Time(s) |
57.33 KB |
671 Time(s) |
Posted: Fri Oct 05, 2007 1:54 pm Post subject: tail wheels |
John A.
Thanks for writing back, and a big thanks for the pictures. I would never
have thought of that. It is a great way to protect the spring and I believe
it is a bit more control over the sway of the gear. I will do that same
thing to mine this winter.
John Oakley
Speedster 4 land and short wings
912ul cap
