jojatek86(at)yahoo.com Guest
Posted: Mon Oct 01, 2007 5:54 am Post subject: Electrical System |
I'm trying to think about electrical system and avionics for my Lightning that I plan to order as soon as I can.
I'm just getting started. What size is the alternator on the 3300? Do most folks use 12v or 24v systems? How much info comes from Arion? If there is a recommended wiring diagram in the build manual, can I get (order) a copy?
Thanks in advance for any info y'all can supply. I've got to have something to work on while I save up.
Pat Phillips
Lawrenceville, GA
Fussy? Opinionated? Ioo!'s user panel and lay it on us. [quote][b]
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
vettin74(at)yahoo.com Guest
Posted: Mon Oct 01, 2007 10:22 am Post subject: Electrical System |
Pat...
The jabiru engine uses a 12V system...the alt is 20 amp continues and 30 amp peak. we do not have any type of wiring diagram because most panels are different. The kit comes with a odessy 625 battery. The engine comes with a starter solenoid, regulator rectifier, and a wiring digarm to wire the systems correctly for engine operations. Some customers do choose to use a master relay, it is up to you as the builder to customize the electrical as you see fit.
Nick
Pat Phillips <jojatek86(at)yahoo.com> wrote:
[quote] I'm trying to think about electrical system and avionics for my Lightning that I plan to order as soon [quote][b]
Posted: Mon Oct 01, 2007 7:15 pm Post subject: Electrical System |
Thanks Nick!
Pat
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
