raimo.toivio(at)rwm.fi Guest
Posted: Thu Sep 27, 2007 11:14 am Post subject: Tire question - cannot fly before information |
All
I was flying today w my mono and one friend.
Suddenly we got some bad weather and clouds lowered
to the 600 feet from the ground. Wind was 13 knots
and 90 degrees from the right side. I was quite stressed
when landing and let is say I "forgot" to pull the stick
fully back. So I did a one wheel landing with that wind.
There was some quite sharp and fast S-turns while landing
but I managed to keep it in control and in one piece.
Now I really know why I have to have legs.
The Europa rudder must be quite effective!
I have to say I was not very proud of that landing and
so I was forced to do it again - just to show to my friend
it is possible to land straight and beautiful (and it was).
After 2nd landing we noticed the brake calliber has hit to
the tire side. I have an original Europa Titan Turf Glide
8.00-6 tire. In manual they say use 1,2 bar but I have
used to use 1,8 bar. Today - because of the cold weather
and my laziness - there was only 1,0 bar.
The brake calliber has hitted all the summer to the tire
and I have noticed earlier those "marks" only
- no significant wear almost at all. That is why I have
decided to update real Aircraft tire and to the size 7.00-6.
Now - today and with all the earlier landings
- the brake calliber has "eaten" tire side let
is say 1,0 mm (=0,04").
Somebody may think it was a "hard" landing but it
was not: my G-meter w register showed only -0,4/+1,8G.
Question:
HOW THICK IS THE SIDE OF the Titan Turf Glide?
If it is less than 2 mm - I cannot fly before new tire.
If somebody has a spare Titan tire, please measure the
side thickness. Thank you. Would like to get some
answers asap and hope it is more than 3 mm thick!
Raimo
OH-XRT #417, 38 hrs so far, no specified grins but very happy
20.29 KB |
490 Time(s) |
josok-e(at)ukolo.fi Guest
Posted: Thu Sep 27, 2007 12:14 pm Post subject: Tire question - cannot fly before information |
Raimo,
Difficult to know how thick it is without slicing it open.
As long as you don't see any of the reinforcement material, i would not worry, not for some local flying. But of course, order a new one right away!
But why change the concept? It should be an 8x6 tire, mine is an aircraft tire and has no marks. The right size is available, in aircraft quality. The pressure is advised as 18 psi or 1.2 bar.
My tire was slowly loosing air, which was caused by abrasion to a quality control (sic) sticker in the inside of the tire.
Jos Okhuijsen
Visit - www.EuropaOwners.org
Posted: Thu Sep 27, 2007 3:44 pm Post subject: Tire question - cannot fly before information |
Raimo
I wonder if the basic requirement to avoid the S's all over the runway
is to never let the airplane land until the stick is on the back stop?
I flew Europa monos for 5 years until one day, in another Europa I had
never landed before I S'd all over. It happened twice in that airplane.
Checking tailplane deflections after the first event showed not enough
up elevator so no downforce.
Graham
Raimo Toivio wrote:
| Quote: | All
| Quote: | Raimo
Graham Singleton
Tel: +441629820187
Mob: +447739582005
dg.watts(at)talktalk.net Guest
Posted: Fri Sep 28, 2007 12:20 am Post subject: Tire question - cannot fly before information |
Raimo,
I have never actually cut one of the factory supplied tyres open, but after
a couple of years of operating it I got a puncture (luckily on taxi out). To
try and find the small point that had caused it I placed my hand inside the
tyre with the other on the outside.
I have to say that the rubber material is very, very thin and although I
re-used the tyre (after repair to the tube) for a few weeks, I straight away
got in a replacement regualr aircraft tyre (which Europa now supply). This
has several advantages. Thicker rubber, stiffer wall (less sideways roll)
and more clearance with the undercarriage frame legs.
I know this is not the firm measurement that you required, but personally,
if there was any piont scoring, as you would get with a brake calliper score
mark, I would definitely not use the tyre. Whilst we used the original tyre,
we did have some marks made my the undercarriage legs, but that was more
like a polishing mark than a scored mark, and whilst I wasn't happy with it,
I did put up with it, whilst monitoring it all the time.
Dave Watts
Europa Mono Classic 229 with 1250 hrs.
Question:
Raimo
Posted: Fri Sep 28, 2007 1:20 am Post subject: Tire question - cannot fly before information |
Jos
are you sure there is reinforcement
material in the sides also???
My tire is too fat and wanna have
slightly narrower one. Cannot understand
what is the reason you have no tire contact
to the brake calliber! Same size, same stuff !
Earlier I asked recommendations for tire
and most of us prefer AirTrac 7.00-6.
My idea was to change tire during winterstop,
but obviously I have to do it immediately if
I want to fly. Just hate that job!
I know succested pressure is 1,2 bar
but I still do like to use 1,8 bar as
do many other Europa mono pilots too.
We should have our DOTH soon
- we could compare our tire-brake calliber combination.
Wishes, Raimo
Posted: Fri Sep 28, 2007 1:45 am Post subject: Tire question - cannot fly before information |
Graham
My tailplane declections are perfect.
I got Sīs because I was careless!
My fault - plane is perfect!
I have completed so far about 100 landings
and no difficulties at all. My most demanding
landing was so far in Endealave during fly-inn
three weeks ago. Wind was 24G38, headwind,
grass runway, lenght 600 metres. Stefan Ingemarsson
from Sweden did it also succesfully.
Wishes, Raimo
Posted: Fri Sep 28, 2007 2:03 am Post subject: Tire question - cannot fly before information |
Thanks Dave for safety information!
Now I know it is "thin".
It will be quite an interesting moment,
when I next time land with that tire!
I still would like to know to make my conclusions:
1) what is the exact thickness of the original
tire side? Somebody has an uninstalled tire /tyre
- please could he measure it?
2) are there some reinforcement material in the sides also
as Jos suppose? I am talking about Titan Turf Glide tire.
3) why I have some slightly contact with tire and brake calliber?
Is it only my problem? If I change to the size 7.00-6,
that contact is away - am I right?
4) what happens when landing with empty mono main wheel?
Or when it bangs during first touch?
Total catastrophe or what?
If so I hope nobody know!
Have a nice weekend, Raimo
OH-XRT #417, flying w broken main tire...
Posted: Fri Sep 28, 2007 8:19 am Post subject: Tire question - cannot fly before information |
Raimo,
I witnessed Jim Naylor have a blowout as he touched down at our grass strip
at Laddingford.
It was not a total disaster, he just stopped VERY VERY quickly.
He thought he had the brake on, and just made sure he kept full back stick.
Dave Watts
karelvranken(at)hotmail.c Guest
Posted: Fri Sep 28, 2007 12:33 pm Post subject: Tire question - cannot fly before information |
Dear Raimo,
The tickness of the tire side is 7 mm. From the inside it looks like fabric
impression, so I suppose it is reinforced. 3) yes. 4) So far I have no
experience and I will not do it for you.
S landings occur when you drink Koskenkorva vodka before flight.
SS landings happened during WWII.
Friendly yours,
Karel Vranken
raimo.toivio(at)rwm-syste Guest
Posted: Sun Sep 30, 2007 12:07 pm Post subject: Tire question - cannot fly before information |
Thanks Karel for measurement
7 mm is great - I have now 5-6 mm
left and the reinforcement material I hope.
Please confirm you measured
Titan Turf Glide Tire!
Earlier I asked some recommendations
for mono tire and a great majority of you
suggested me to install size 7.00-6
and AirTrac was a clear winner.
So my conclusion is it cannot be worse
than the original golf car tire (golf carīs
max taxi speed is about 10 knots, it has
four tires and the weight /tire is less than
150 kg /340 lbs - when touching Europaīs
speed is 5 times more and weight 2,5 times
more + G-forces).
I believe aircraft quality tire size 8.00-6 does not hit
normally caliber because of itīs overall quality and accurate
measurements. Tolerance is anyway minimal between
it and caliber. Non-aircraft tires may hit
bacause of the varies in quality and their limp
sides. Same reason for Kingleyīs differencies
with diameters.
My wife suggests one reason for the contact:
my caliber is maybe just bigger than normal one !
Karel, S landings or even SS-landings are better
than U or L -landings. I saw one L-landing in
Aalborg Denmark 9/9/07. It was SAS`s Dash 8
full of passengers and right side gear collapsed.
I cannot understand why they did not land to
the grass in the clean configuration.
It was awful to see but happily no fatals.
Anyway I will go on flying with this tire to the end of
this flying season. I promise I stop landing
if reinforcement material is visible or even
inner tire.
And have a CM- DOTH with Jos (caliber measurement).
Thanks for comments, all of you.
Raimo,
OH-XRT (with big caliber)
Posted: Sun Sep 30, 2007 3:38 pm Post subject: Tire question - cannot fly before information |
Raimo,
The measurements were done on Titan Turf Glide tire that I didn't use. The
tire on my mono is a Condor.
Karel Vranken.
