		UVTReith(at)aol.com Guest
				 Posted: Fri Feb 17, 2006 7:53 am    Post subject: Tie-Bar / Gusset Plate Assembly |
				Hi friends,
 Maybe I have made something wrong.
 The tie-bar is installed, the plywood blocks too (builder manual page 27-6  -
 27- .
 Now I would like to fit the gusset plates, but I see no way to drill on the
 right side the outer holes through the plates, tie-bar and plywood block, as
 there is a tank stud in my drilling line.
 Is there somebody out in the world, who could give me a clue how to solve
 this problem.
 Many thanks,
 Bruno Reith - Monowheel XS kit 379
 _uvtreith(at)aol.com_ (mailto:uvtreith(at)aol.com)
		Ivor Phillips
				 Posted: Fri Feb 17, 2006 9:54 am    Post subject: Tie-Bar / Gusset Plate Assembly |
				I used a 12 inch long drill bit, once started you can make it curve slightly
 to miss the Tank inlet,
 works a treat!!
 The other way is to use a pancake drill attachment, they work well in
 confined places, Check out Ebay for used ones,
 Item number 4441300173
 regards
 Ivor Phillips
		rich(at)rscanlan.freeserv Guest
				 Posted: Fri Feb 17, 2006 11:54 pm    Post subject: Tie-Bar / Gusset Plate Assembly |
				Hi Bruno, this had me stumped for a couple of days, as I have the fibreglass
 fuel tank I believe the access is worse.To the rescue came a mate who works
 for a local airline, and from his toolbox he produced an airdrivendrill with
 90 degree head on it. As it uses collets for the chuck it has a very small
 head diameter, hence you can get close to the side of the cockpit module.
 two weeks head scratchin', two minutes to do the job. About eighty quid to
 buy, so you may need to be resourceful in your search to borrow one!
 regards
 Richard Scanlan
