		poneill(at)irealms.com Guest
				 Posted: Tue Sep 25, 2007 3:46 am    Post subject: QB Wings: Page 16-2 Step 3 |
				I'm still working through double checking all the QB Wings+Fuse plan steps
 and encountered an issue with one of the uncompleted wing steps.
 Page 16-2 Step 3 where you #19 drill the center nut plate holes for the wing
 root fairing attach.  The center holes have not been drilled, so I am
 drilling them.  The problem is that there are 3 layers of aluminum already
 riveted together which must be drilled through: rib, wing walk doubler, and
 top skin.  When drilling out the center hole, I am getting bur/chip
 production between the layers.
 I'm using a #19 jobber bit and going slow, but I am not able to avoid
 separation of the layers due to chips.  It's too tight to use a chip chaser
 without damaging the skins.  I was able to clean out the first two and then
 stopped to research before proceeding.
 Was this step completed for any others with QB wings or is this a standard
 task for the builder to complete?
 Any suggestions for avoiding the burrs/chips in between the layers while
 drilling?
 Best Regards,
 Patrick 40715
		ScooterF15
				 Posted: Tue Sep 25, 2007 5:49 am    Post subject: QB Wings: Page 16-2 Step 3 |
				Patrick,
  I had the same issue with my QB kit, although, I don't have any suggestions  for you. Just do the best you can. It is certainly a good idea to check  every step in the plans to make sure it was done and done correctly. I spent  probably a week checking/fixing stuff before actually starting work. I  found it quite disturbing that they failed to drill the center holes  for almost every single nut plate installed in the QB fuse. That makes  it pretty hard to drill and properly debur those holes (especially when  there are multiple layers of aluminum). Good luck.
  -Jim
  40134
  In a message dated 9/25/2007 7:47:50 A.M. Eastern Daylight Time,  poneill(at)irealms.com writes:
   	  | Quote: | 	 		  -->    RV10-List message posted by: "Patrick ONeill"    <poneill(at)irealms.com>
 drilling?
 Best Regards,
 Patrick  40715 |
  Jim "Scooter"  McGrew
 http://www.mit.edu/~jsmcgrew
 See what's new at AOL.com and .
				 Posted: Tue Sep 25, 2007 7:07 am    Post subject: QB Wings: Page 16-2 Step 3 |
				If you use a couple of cleco clamps to hold the skins together, then run a #40 bit first, then #30 and then go up to #19, that should help a lot on the burrs.  The cleco clamps should do a fairly good job of holding the skins together.  Also, if you just put a little bit of pressure and let the bit do the work, the skins will not be separated as much while drilling.
 Jesse Saint
 Saint Aviation, Inc.
 www.saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
 From: JSMcGrew(at)aol.com [mailto:JSMcGrew(at)aol.com]
  Sent: Tuesday, September 25, 2007 9:48 AM
  Subject: Re: QB Wings: Page 16-2 Step 3
 Patrick,
 -Jim
 40134
  drilling?
  Best Regards,
  Patrick 40715   |
   [quote]   [b]
		Bill Reining
  Joined: 13 Aug 2007 Posts: 13 Location: Oakland, California
				 Posted: Tue Sep 25, 2007 8:57 am    Post subject: Re: QB Wings: Page 16-2 Step 3 |
				Be careful, there is a gotcha here.  One of the nutplates is different, such that the screw hole is on the side, rather than the middle.  The plans are correct.  See Tim Olsen's comments in his gotchas section here: http://www.myrv10.com/tips/gotchas.html
  _________________ Bill (and Jon) Reining
40514 |
		VHMUM(at)bigpond.com Guest
				 Posted: Tue Sep 25, 2007 12:35 pm    Post subject: QB Wings: Page 16-2 Step 3 |
				Use a step drill to just under 19 and then 19 drill and then it will be
 perfect
 Chris
