vanncovi(at)yahoo.com Guest
Posted: Tue Sep 25, 2007 7:37 am Post subject: trim tab |
I have a question about the electric trim tab in the elevator. I purchased a partially built kit and the previous builder did not use the trim kit. Any suggestions for a retrofit? Thanks, Vann, NC
Luggage? GPS? Comic books?
Posted: Tue Sep 25, 2007 8:11 am Post subject: trim tab |
Vann,
The elevator is removable. If you'd built the elevator, you'd have to
have it completed to install the trim tab anyway, so I'd recommend you
consider adding
the externalized trim tab on your bench at home and follow the guidance
provided in the plans. The only complication is extending wiring for
this thru the plane, but that's
the worst of it. If you need more info, email me off site.
See link of installation,
http://www.macsmachine.com/html/trimtelevatortrimtabs.htm
vann covington wrote:
| Quote: | I have a question about the electric trim tab in the elevator. I
davgray(at)sbcglobal.net Guest
Posted: Tue Sep 25, 2007 8:51 am Post subject: trim tab |
This is not a problem since the trim tab can easily be cut after completing the elevator. Check out the Zenith Builders web site for latest drawings to be sure you are making the full span version of the tab.
Ron Lendon
