Kolb MKII Fatality
PostPosted: Mon Sep 24, 2007 10:48 am    Post subject: Kolb MKII Fatality Reply with quote
Just read in the FAA Preliminary Data Base:
AIRCRAFT CRASHED INTO A FIELD UNDER UNKNOWN CIRCUMSTANCES, THE ONE PERSON
ON BOARD WAS FATALLY INJURED, NEAR ATHENS, TN
I have no idea who was flying or know the owner of the MKII. Steven Green
flies out of Athens, TN. He may know the circumstances.
FAA Registry
N-Number Inquiry Results
N43046 has multiple records
Aircraft Description
Serial Number M2-121 Type Registration Individual
Manufacturer Name KOLB Certificate Issue Date 02/24/2005
Model MK II Status Valid
Type Aircraft Fixed Wing Single-Engine Type Engine Reciprocating
Pending Number Change None Dealer No
Date Change Authorized None Mode S Code 51223041
MFR Year 1989 Fractional Owner
NO
 Filesize:  49 Bytes
 Viewed:  6627 Time(s)
PostPosted: Mon Sep 24, 2007 11:00 am    Post subject: Kolb MKII Fatality Reply with quote
Green
Sorry, system dropped the b ottom of my info:
Registered Owner
Name ROTH JERRY D
Street 5022 STUMP RD
City MARYVILLE State TENNESSEE Zip Code 37803-0747
County BLOUNT
Country UNITED STATES
PostPosted: Mon Sep 24, 2007 11:06 am    Post subject: Kolb MKII Fatality Reply with quote
Looks like the owner was killed in the crash.
Here is what I could find:
http://hosted.ap.org/dynamic/stories/T/TN_PLANE_CRASH_TNOL-?SITE=TNMAR&SECTION=HOME&TEMPLATE=DEFAULT
Steven Green
PostPosted: Mon Sep 24, 2007 6:12 pm    Post subject: Kolb MKII Fatality Reply with quote
John and all,
There is some speculation by locals that he became unconscious, He was 72.
Steven
Steven Green
Ralph B
PostPosted: Tue Sep 25, 2007 7:21 am    Post subject: Re: Kolb MKII Fatality Reply with quote
Steven Green wrote:
John and all,
Steven
I knew Jerry. He was originally from the Minneapolis area. He completed his Mark II in 1989 and I test flew it for him. He had an accident in it when the 503 air cleaner became saturated with water during a rain the night before. The engine ran rough on takeoff and he tried a downwind landing in a short field and damaged the aircraft, but wasn't hurt.
Jerry retired and moved to Tennessee about 15 years ago and had the aircraft registered there.
I will try and get more details about this accident.
Ralph B
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
JetPilot
PostPosted: Thu Sep 27, 2007 6:48 pm    Post subject: Re: Kolb MKII Fatality Reply with quote
I don't believe that water in the air cleaner from a rain shower earlier in the day would have caused the 503 engine to run rough. I have flown my MK III through rain, and no problem with the filters getting wet, even sucking water inside them.
Even if the filters were totally soaked with water, any water would have been very well sucked out of them before the airplane even broke ground at full throttle.
Mike
Kolb MK-III Xtra, 912-S
aoldman(at)xtra.co.nz
PostPosted: Fri Sep 28, 2007 2:48 am    Post subject: Kolb MKII Fatality Reply with quote
I have experienced on at least two occasions now that I have had low RPM on
full throttle at take off and on both these occasions removing the air
filter fixed the problem.The first time was at a fly in to a car race track
I landed on the back straight. The Kolb MK111 with 503 was parked up for
about 3 hours in misty showery weather. When I went to depart the engine did
not reach its normal rpm. I aborted the take off and removed the air cleaner
and the problem disappeared. When the air cleaner dried out and was put back
on it worked fine.I find the air cleaner needs washed in hot/warm soppy
water about every 25 hrs .
I believe that water from a shower would/could make the engine run rough. I
would need to have more information to form an opinion in this case. I have
never experienced this problem by simply flying through rain.
Down under
