kuffel(at)cyberport.net Guest
Posted: Sat Sep 29, 2007 3:41 pm Post subject: Combined Switch/Circuit Breakers |
<< Which part numbers do you recommend for aircraft 12 VDC use? >>
I used AIRPAX R11-51-nn.nA-G06EV-S Hydraulic/Magnetic Circuit
Breaker/Switches available from Onlinecomponents.com for $11.05.
These are gray body/white flat rocker switches with black
ON-Off marking. nn.n is the amperage rating with 2/5/10/15 amps
available in this style.
Mouser stocks a similar unit from Carling with a black body for
$18.53, see part series MA1-B-34-xxx-1-A12-B-C where xxx is the
amperage code, available ratings 5/7.5/10/15/20/25 amps.
Other similar styles are available including angled rockers and
international | - O markings.
Tom Kuffel
handainc(at)madisoncounty Guest
Posted: Sat Sep 29, 2007 5:28 pm Post subject: Combined Switch/Circuit Breakers |
Thanks, Tom -
That saved me hours of looking through specs!
M. Haught
The Kuffels wrote:
<kuffel(at)cyberport.net>
These are gray body/white flat rocker switches with black ON-Off
marking. nn.n is the amperage rating with 2/5/10/15 amps available in
this style.
Tom Kuffel
