d-m-hague(at)COMCAST.NET Guest
Posted: Sun Sep 23, 2007 5:46 pm Post subject: I finally flew it! |
Patience is rewarded and I finally flew my Ultrastar today! (I don't count
yesterday's short crow hop as a flight). My only complaint is that it was
too short... as soon as I was high enough to be committed, the engine
started surging. Fortunately I only had to climb a little to be high
enough to make the sod farms south of the airport, then throttling back
smoothed things out a bit, keeping me aloft in a slow descent. Gave me
enough to go around and get it back to the runway... made a real fast steep
approach since I didn't have the opportunity to feel it out and do a few
stalls as I'd planned. Got it down OK though, my only complaint is that I
can't even say how it handled (except that it was no trouble), in that
situation you just "do it" without thinking about it.
Turns out there was an air leak at the fuel filter, which I at first
attributed to the cheap worm screw hose clamps that were on the plane when
I bought it. However, after removing them, trimming the lines, and
securing them with several wraps of safety wire, I still get air bubbles
and little fuel in the filter at full power (on the ground, of course!) As
it got dark I didn't have time to investigate further; I'm wondering if the
filter itself (the clear plastic one with the sintered bronze element that
Aircraft Spruce sells for ultralights) maybe has a leak, perhaps a bad
plastic weld... anybody ever heard of such a thing?
With luck I'll be able to get new clamps and filter on tomorrow after work,
and squeeze in a longer flight before sunset.
-Dana
"I'm a lawyer." "Honest?" "No, the usual kind."
jindoguy(at)gmail.com Guest
Posted: Sun Sep 23, 2007 6:14 pm Post subject: I finally flew it! |
Dana, Easy enough to check the seam on the filter for leaks, just smear a coating of wheel bearing grease around the seam and see if the bubbles go away. Old Harley trick to check for intake leaks.
Rick
On 9/23/07, Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)> wrote: | Quote: | --> Kolb-List message posted by: Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)>
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
d-m-hague(at)comcast.net Guest
Posted: Sun Sep 23, 2007 6:24 pm Post subject: I finally flew it! |
At 10:14 PM 9/23/2007, Richard Girard wrote:
| Quote: | Dana, Easy enough to check the seam on the filter for leaks, just smear a
Good idea, thanks, I'll try that... I'm going to replace it anyway, filters
are cheap, but it's nice to know for sure.
-Dana
Posted: Sun Sep 23, 2007 6:31 pm Post subject: I finally flew it! |
Oh yeah... a few pix at
http://smg.photobucket.com/albums/v486/flyparafan/Kolb/
Note the gap seal too, since we're having that discussion...
-Dana
wenquist(at)comcast.net ( Guest
Posted: Mon Sep 24, 2007 4:56 pm Post subject: I finally flew it! |
If you have a bing carb the surge problem may be within. Open the top end of the carb and check
whether or not the e-clip on the jet needle is placed on the wrong side (above or below) of the spring cup. If the e-clip is on the wrong side the engine will surge erratically at higher rpm.
-------------- Original message --------------
[quote] --> Kolb-List message posted by: Dana Hague
can't even say how it handled (except that it was n o trou ble), in that
-Dana
& gt; --
Posted: Mon Sep 24, 2007 5:21 pm Post subject: I finally flew it! |
At 08:56 PM 9/24/2007, Walt Enquist wrote:
| Quote: | If you have a bing carb the surge problem may be within. Open the top end
of the carb and check whether or not the e-clip on the jet needle is
Thanks Walt, it was definitely an air leak (and it's a Mikuni carb
anyway). The problem appears to have been a bad (new out of the box from
Aircraft Spruce) primer bulb. It didn't look that way as the bubbles
appeared at the filter, but replacing both the [also new] filter and hose
clamps didn't solve it. Putting the original primer bulb back on solved
the problem. I haven't disassembled the suspect bulb yet, but it looks
like it was restricting fuel flow, so the pump was able to generate enough
suction to pull air in anywhere it could, even though tightly clamped.
With the problem fixed I enjoyed a beautiful 1/2 hour flight tonight.
-Dana
lcottrell
Posted: Mon Sep 24, 2007 5:50 pm Post subject: I finally flew it! |
| Quote: | Aircraft Spruce) primer bulb.
That is the second primer bulb from ACS that was defective out of the box.
That is just the few people on this list, and there are two of them. Wonder
if the whole batch is defective.
Larry C
Thom Riddle
Posted: Tue Sep 25, 2007 3:56 am Post subject: Re: I finally flew it! |
Dana,
I've very glad to hear you flew without the fuel starvation problem.
The following is my 2 cents worth on primer bulbs.
Most of the primer bulb installations I've seen are either in parallel or series with the pulse pump and therefore are being used only as a hand pump to fill the float bowl. Why so many do it this way is a mystery to me since the purpose of the PRIMER is to give a little squirt of fuel into the throat of the carburetor for a quick start. Having it plumbed (either parallel or series) to the float bowl does not accomplish this.
When I bought my Firestar it had no primer at all and took many many pulls to get it started with the proper starting technique with the float bowl full. I bought a high quality PRIMER bulb from West Marine and installed it ACCORDING TO THE ROTAX MANUAL, which means it is teed off of the fuel supply line before the pulse pump (between tank and pump) and then goes to the primer fitting on the carburetor, which is downstream of the venturi and butterfly valve. I also installed a shutoff valve between the tee and the primer bulb to prevent the pulse pump from sucking air if the check valve in the primer fails.
When starting cold, I open the shutoff valve, give the bulb one squeeze (squirting a bit of raw fuel into the throat of the carburetor), shut off the valve, and pull the starter rope once and it starts. The whole purpose of a primer bulb is to get a squirt of raw fuel into the intake so it will start on a single pull when cold. Once it is running, the pulse pump quickly fills the float bowl if it was low due to evaporation from sitting for a while. The primer bulb's primary purpose is NOT to fill the float bowl which is all it will do if it is plumbed the way most folks do it, contrary to the Rotax manual. Having the primer bulb in the fuel system feeding the float bowl creates another point of potential failure, which it sounds like maybe was the problem you had. If the primer bulb is plumbed into the primer fitting on the carburetor and isolated with a shutoff valve, it is not part of the fuel supply system when running.
Attached is a photo of the 2-stroke installation manual figure showing the primer installation schematic. It shows a plunger type primer which does not need a shut-off valve but the bulb type should have a shut-off valve to isolate it in case of check valve failure.
35.26 KB |
377 Time(s) |
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Tue Sep 25, 2007 9:06 am Post subject: I finally flew it! |
At 07:57 AM 9/25/2007, Thom Riddle wrote:
... the purpose of the PRIMER is to give a little squirt of fuel into the
parallel or series) to the float bowl does not accomplish this.... The
it will do if it is plumbed the way most folks do it...
Makes sense. On my engine (Cuyuna, with Mikuni carb), there is no primer
port, but there is a choke lever. Cold, it will start on the first pull
with the choke on. Between flights, if everything is sealed well (it seems
to be, now), the fuel line should stay full, but if not (or at initial
startup), it could take an awful lot of cranking to fill the fuel system up
to and including the float bowl.
I had considered tee-ing in a bypass around the primer bulb with a couple
of check valves, but that just adds more complication and more potential
leak points. I also considered putting in a primer hole and adding a
plunger type primer, deleting the bulb, and using the plunger primer to
pull fuel up if necessary... but it'd still need a check valve to keep from
pulling fuel (or air) back from the carburetor if the float needle is open.
One option for priming could be a tee off the fuel line downstream of the
bulb, with a valve, so that when you open that valve the bulb would force
fuel into the carburetor throat, but with the valve closed it'd still be
able to fill the fuel line and bowl.
As for putting the bulb series or parallel to the pulse pump, I guess it's
a matter of which do you think is more likely-- the bulb leaking or getting
blocked?
Just random thoughts... not sure which direction I want to go.
-Dana
Thom Riddle
Posted: Tue Sep 25, 2007 9:39 am Post subject: Re: I finally flew it! |
Dana,
If you have a squeeze bulb in place to fill the float bowl, then adding a tee and shut-off valve to prime the carb too, that would satisfy both requirements.
The parallel/series debate has been beat to death. But for what it's worth, Standard Category Type Certificated aircraft put auxiliary fuel pumps (which a squeeze bulb is in this case) in parallel with the primary pump, but these are invariably very reliable electric pumps, not squeeze bulbs. This provides an alternate path for the fuel in case the primary pump becomes blocked or otherwise fails. That said, our Special LSA Allegro (factory built) has the aux. electric in series with the mechanical engine driven pump, but this is done to avoid the rather difficult plumbing problem that would result if piped in parallel.
Buffalo, NY (9G0)
- Anonymous |
russ(at)rkiphoto.com Guest
Posted: Tue Sep 25, 2007 11:50 am Post subject: I finally flew it! |
FWIT, when I put the 180hp conversion on my 170; it required an
electric fuel pump in series with the engine-driven mechanical pump.
This in addition to gravity-feed; which in high-wing Cessnas ( at
least in normal flight attitudes) is all you normally would ever need.
Original engine (Continental 0-300) had a single mechanical fuel pump
on the engine. Don't know why they added the electric pump for the
180 conversion.
Must have found some weird maneuver that required more fuel -- or
someone's brother-in-law sells fuel pumps.
Never saw or heard of a fuel filter bypass. This DAR sounds ???
On Sep 25, 2007, at 1:40 PM, Thom Riddle wrote:
Dana,
Thom in Buffalo
N221FA Allegro 2000 912UL
N197BG FS1/447
"Setting an example is not the main means of influencing
another, it is the only means."
Albert Einstein
http://forums.matronics.com/viewtopic.php?p=136374#136374
planecrazzzy Guest
Posted: Tue Sep 25, 2007 2:31 pm Post subject: Re: I finally flew it! |
Here's a picture of my primer bulb "By-pass"
Just close the valve , squeeze the bulb , then open the valve...
Gotta Fly...
Mike & "Jaz" in MN
58.32 KB |
378 Time(s) |
57.73 KB |
369 Time(s) |
