markeypilot(at)yahoo.com Guest
Posted: Thu Sep 20, 2007 11:22 am Post subject: Glasair-List Digest: 2 Msgs - 09/18/07 |
Hydrocarbons and alcohols will indeed leach different types of monomers and oligomers - both are low molecular weight base chemistries for reactive resin systems. However, when properly formulated and reacted - i.e., cured - these materials no longer exist but are bound up in and make the highly crosslinked matrix that is also reacted to the glass [or carbon fiber or aramid, etc.]. The original epoxy systems had issues with toxicity, reactivity and formulation, but these same systems today are routinely used if not for the actual tank then as the sealants around the seams of metalized tanks. These same vinyl ester systems are also used to make industrial chemical tanks.
A prudent builder will always flush a new vinyl ester fiberglass tank out with solvent before using it in a critical flight test. But there is little reason to not consider testing and using E85 in a composite fuel tank system.
As for the water issue, a correctly formulated E85 is no worse than standard AvGas. Go read the original CAFE reports.
More of this can be read by Goggling the topic. Som links to start on:
http://www.age85.org/PressReleases/index.cfm
http://txskyways.com/
john
Glasair-List Digest Server <glasair-list(at)matronics.com> wrote:
Quote: | *
________________________________ Message 2 _____________________________________
Time: 01:28:06 PM PST US
Subject: Fuel tanks
Ethanol leaches resin out of fiberglass. And Ethanol absorbs water.
">Check out the hottest 2008 models today at Yahoo! Autos. [quote][b]
| - The Matronics Glasair-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
Craymondw(at)aol.com Guest
Posted: Fri Sep 21, 2007 10:06 am Post subject: Glasair-List Digest: 2 Msgs - 09/18/07 |
Some Glasair builders coated the inside skin leading edge areas to prevent fiber glass fibers from getting in their fuel system. If they didn't use exact ratio of resin to catalyst and the resin hasn't fully cured, they may have problems with ethanol.
Make AOL Your Homepage.
