Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Sat Sep 22, 2007 7:33 am Post subject: Drag reduction |
I have a nagging thought to offer. Having experienced the external
mods on a nymber of different machines, it occurred to me to mention that
one may want to have a confab with the designer concerning the change in
sidereal area of the mainwheel drag reduction. I intended to do that but
want to fly her basic first for comparison later.
A number of ahead-of-CoG mods made a big difference in the spin
characteristics, partricularly after the third rotation - that's one
advantage of the Europa - a demonstrated 12-turn spin in each direction - a
rare event. Note the ventral strakes on an F16. These have been called Lawn
Darts in the past.
We don't want someone trying to screw a EUPA into the back garden
from 13,000 feet.
Ferg
TELEDYNMCS(at)aol.com Guest
Posted: Sun Sep 23, 2007 6:40 am Post subject: Drag reduction |
In a message dated 9/23/2007 2:58:46 AM Eastern Daylight Time, europa-list(at)matronics.com writes:
| Quote: | I believe the biggest improvement in reducing drag would be found in the
engine cowl area. Closing off the gills would be the first thing (they add
no value to the plane). Second would be to clean up the radiator opening
and following duct, it is too large for the size of this engine and is
rather messy. Then clean up the radiator exit, it is very messy back there. |
Hi Terry,
Or, you could install a Jab and do away with the radiator, gills and the stock, stubby Europa cowl altogether.
The 1800+ fpm climb rate I'm regularly seeing with my Jab is nothing to sneeze at, nor is the $10,000 lower price over the 912S.
John Lawton
Whitwell, TN (TN89)
N245E - 115 hours and going strong (and soon to be much faster, too)
See what's new="_blank">Make AOL Your Homepage.
Gilles.Thesee(at)ac-greno Guest
Posted: Sun Sep 23, 2007 6:55 am Post subject: Drag reduction |
John,
| Quote: | you could install a Jab and do away with the radiator, gills and the
Of course an aircooled engine doesn't need a coolant radiator, but the
cooling needs are about the same !
Due to aerodynamic and thermodynamic considerations, an air-cooled
engine will always drag a little more than its liquid-cooled
counterpart. That is provided the cooling installation is equallly well
designed in both cases.
Concerning the Europa cowl, I agree with you it seems in need of some
aerodynamical improvements
Would you care to share any precise speed measurements (3 GPS runs, max
take off weight, record of altitude, OAT, etc.) ?
My Jabiru buddies are getting soooo discreet when it comes to actual
performance ;-(
Best regards,
Gilles
http://contrails.free.fr
Posted: Sun Sep 23, 2007 7:23 am Post subject: Drag reduction |
John
I have some friends in UK with a Jab 6 who are having cooling
difficulties, would you like to copy me please when you reply to Gilles?
Graham
TELEDYNMCS(at)aol.com wrote:
| Quote: | In a message dated 9/23/2007 2:58:46 AM Eastern Daylight Time,
/I believe the biggest improvement in reducing drag would be found
in the
(they add
opening
back there/.
Hi Terry,
John Lawton
Whitwell, TN (TN89)
Graham Singleton
Tel: +441629820187
Mob: +447739582005
