Landing gear fairing cuff
gptyler(at)metrocast.net
PostPosted: Thu Sep 20, 2007 4:06 am    Post subject: Landing gear fairing cuff Reply with quote
I didn't build my -6, so I hope one of you can help me. The fiberglass cuff that closes the gap between the landing gear leg fairing and the fuselage. are held in place by a spring and wire attachment. I assume it was part of the original build plan. One of these springs broke and I replaced with a similar looking hardware store spring. It did not last one flight. Can anyone Identify the spring and a source? Thanks
kahuna
PostPosted: Thu Sep 20, 2007 4:50 am    Post subject: Landing gear fairing cuff Reply with quote
It would not have been part of the original kit and is a design area left up to the builder.
Ace hardware in the aviation section is probably a good choice for replacement springs.
Best,
Mike
[img]cid:1__=08BBF9CFDFD5DBD98f9e8a93df938(at)us.ibm.com[/img]"George Tyler" <gptyler(at)metrocast.net>
[img]cid:3__=08BBF9CFDFD5DBD98f9e8a93df938(at)us.ibm.com[/img]
To
<rv-list(at)matronics.com> [img]cid:3__=08BBF9CFDFD5DBD98f9e8a93df938(at)us.ibm.com[/img]
cc
Subject
Landing gear fairing cuff [img]cid:3__=08BBF9CFDFD5DBD98f9e8a93df938(at)us.ibm.com[/img][img]cid:3__=08BBF9CFDFD5DBD98f9e8a93df938(at)us.ibm.com[/img]
?RV-List">[b]http://www.matronics.com/Navigator?RV-List
u>http://forums.matronics.com[/u]
 Filesize:  105 Bytes
 Viewed:  1536 Time(s)
 Filesize:  1.23 KB
 Filesize:  45 Bytes
 Viewed:  1537 Time(s)
panamared5(at)brier.net
PostPosted: Thu Sep 20, 2007 5:24 am    Post subject: Landing gear fairing cuff Reply with quote
I use two bolts with platenuts to hold mine on. One in front and one
on the side. Seems to work well and are easy to take off.
Bob
RV6 "Wicked Witch of the West"
Best,
Mike
Inactive hide details for "George Tyler" <gptyler(at)
"George Tyler" <gptyler(at)metrocast.net> Sent by:
owner-rv-list-server(at)matronics.com
09/20/2007 08:10 AM
Please respond to rv-list(at)matronics.com
To
cc
Subject
?RV-List">http://www.matronics.com/Navigator?RV-List
 Filesize:  105 Bytes
 Filesize:  45 Bytes
PostPosted: Thu Sep 20, 2007 10:04 am    Post subject: Landing gear fairing cuff Reply with quote
Thanks for the info. I was hoping someone would tell me what they did if
not the spring.
