Wing Support Brackets
malins2005(at)yahoo.com
PostPosted: Wed Sep 19, 2007 11:12 pm    Post subject: Wing Support Brackets Reply with quote
I am still trying to find drawings or photos of a bracket system to support the wings of my M3X when folded. Any ideas?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Thai Kolb
Fussy? Opinionated? Impossible to please? Perfect. [url=http://us.te.asp?a=7 ]Join Yahoo!'s user panel[/url] and lay it on us. [quote][b]
NeilsenRM(at)comcast.net
PostPosted: Thu Sep 20, 2007 6:22 am    Post subject: Wing Support Brackets Reply with quote
Tony
This is what I use as a dolly or wing fold bracket for use in my trailer. It might be over kill for what you want but check it out. Note! The picture was taken before I fully covered it with carpet so it would show how it is made.
Rick Neilsen
Redrive VW powered MKIIIC
 Filesize:  60.38 KB
 Viewed:  501 Time(s)
Thom Riddle
PostPosted: Fri Sep 21, 2007 3:26 am    Post subject: Re: Wing Support Brackets Reply with quote
Since I fold/unfold with every flight, I built a wing support dolly that would hold the wings above the tail wires to eliminate the need for folding/unfolding that part for each flight. Attached are some photos.
 Filesize:  89.95 KB
 Viewed:  463 Time(s)
 Filesize:  100.01 KB
 Viewed:  474 Time(s)
 Filesize:  98.5 KB
 Viewed:  468 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
d-m-hague(at)comcast.net
PostPosted: Fri Sep 21, 2007 5:50 pm    Post subject: Wing Support Brackets Reply with quote
folding/unfolding that part for each flight...
Boy, that's high!
If I can get (or afford!) hangar space for my US, I was thinking of making
a dolly that holds the wings *outside* the unfolded tail. Would use a bit
more floor space but not be so high.
-Dana
"I'm a lawyer." "Honest?" "No, the usual kind."
Thom Riddle
PostPosted: Sat Sep 22, 2007 3:50 am    Post subject: Re: Wing Support Brackets Reply with quote
Dana,
Either way saves several minutes from the folding/unfolding process, which is important if it is done every flight. Since I have plenty of unused overhead space and limited lateral space with the other airplane in the hangar, I went up instead of out.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
capedavis(at)yahoo.com
PostPosted: Sat Sep 22, 2007 4:35 am    Post subject: Wing Support Brackets Reply with quote
Thom Good idea I spent several years folding and unfolding my KXP and the most time consuming and the most chance of an assembly error was in the tail and especially the botom cables so I can see the advantage to your method ! Chris
PostPosted: Mon Sep 24, 2007 6:21 am    Post subject: Wing Support Brackets Reply with quote
Thanks very much Rick, a great idea, I'll see how it goes.
Best regards
tony
