rparigor(at)suffolk.lib.n Guest
Posted: Tue Sep 18, 2007 6:52 am Post subject: Dynon AOA homemade 1 of 3 |
Figured this may be of interest, it is a paste from Aeroelectric
Newsgroup.
Will try and attach pics in 2 more.
Ron Parigoris
Date: Monday, September 17 2007 11:51 pm
To: avionics-list(at)matronics.com
Reply-To: avionics-list(at)matronics.com
Subject: Avionics-List: AOA for your Dynon
Full Headers: Display Headers
Attachments: Part 1 noname (TEXT/PLAIN 7bit 1207 bytes) Hide
Part 2 101_1466small.jpg (IMAGE/JPEG base64 338548 bytes) View
Part 3 101_1467small.jpg (IMAGE/JPEG base64 444246 bytes) View
For all of you who have or are thinking of buying the Dynon and think
you would like to be able to use the angle of attack indicator it
doesn't have to cost another $200. I bought my Dynon for the attitude
display and everything else was gravy. It wasn't until after I was
flying with it I even realized that it have the AOA option. Being a
builder oh and cheap too, I though $200 was a lot to pay so I looked
into Dynon's and other AOA devices. Well anyway I made my own probe,
cost nothing time about an hour or so and I can report it works great.
Attached are a couple of pictures of the installation. The trick to ease
of fabrication is that I used copper tubing, easier to solder together.
The pitot tube is at a right angle to the support tube and the
additional tube is angled 45 degrees down. To hold it I made a slot in
the circular piece of 1/8 inch aluminum, I used my mill but it can be
done with a drill and careful file work.. Mine as a snug fit to which I
added epoxy. By the way don't start on how that copper is going to
corrode with the aluminum I keep my plane inside and dry and I haven't
seen any at other interfaces in the past year.
Tim Shankland
UVTReith(at)aol.com Guest
Posted: Wed Sep 19, 2007 8:13 am Post subject: Dynon AOA homemade 1 of 3 |
Hi Tim Shankland and Ron Parigoris,
This is a great story with the AOA device for the Dynon, but I cannot open pictures or so.
Can you send some more info again?
I'm using the EFIS-D100 and have the Europa stall warner tubingsystem installed.
I thought, when I connect the stall warner tube also with the AOA port and the Pitot tube also with the Pitot port of the instrument, that this would be ok. In this case I have both - a superb display in my EFIS and a sound machine above my head.
Do I missed something? Is my solution not working?
Some Input from experts are warmly welcome.
Best Regards,
Bruno Reith
monowheel XS, smart-Brabus + Warp Drive Prop
Nearly ready, instrument + Com/Nav installation and final check is on the list now.
Posted: Wed Sep 19, 2007 8:40 am Post subject: Dynon AOA homemade 1 of 3 |
Hi Bruno
"This is a great story with the AOA device for the Dynon, but I cannot
open pictures or so. Can you send some more info again?"
My Library ISP bounced the pics because they are too large. I tried to
send through my Hotmail account, and bounced because I am not signed up to
Europa Newsgroup.
I sent to you direct from Hotmail. If you can please try and post them to
this thread for others.
Stall warner goes lower pressure near stall, where AOA input for Dynon is
looking for higher pressure near stall.
Don't know what you are going to get with Dynon if you input reverse what
is called for.
Ron P.
josok-e(at)ukolo.fi Guest
Posted: Wed Sep 19, 2007 10:10 am Post subject: Dynon AOA homemade 1 of 3 |
Hi Ron, Bruno
Well, i tried it today finally, that is using the stall warner for the Dynon AoA warner. It does not work. I was hoping that the Dynon would register difference without polarity. It does notice polarity. Ron you were right about it. I have the original Dynon tube, will install that later.
Jos Okhuijsen
Visit - www.EuropaOwners.org
