ernieandjane(at)naxs.net Guest
Posted: Mon Sep 17, 2007 9:37 pm Post subject: New subscriber-1st post-request for info |
From; Ernest Deel ernieandjane(at)naxs.net (ernieandjane(at)naxs.net)
Subject; Request for info;;
I am considering purchasing a KF IV Speedster (s/n JCS 137) project--no FWF except Rotax engine mount. The plane had minor wing-tip and landing gear damage from a high speed taxi incident and the engine was removed for another project. I will want to convert to a tri-gear (nose wheel)
Are approved parts and plans available? >From who and where? Is this a complicated conversion? Requiring welding and reinforcement of fuselage and/or firewall? And will I need to make a decision on which engine before beginning work on the landing gear? A close-up picture or sketch showing how the nose gear brackets are attached would be helpful. Will this be considered a major airframe modification? and what kind of "paper-work" and inspections will be required? (Although I built and flew a Vari-Eze I do not have much expertise with tube and fabric or welding) An opinion (guesstimate?) on cost will also be welcome.
Engines?? Possibly a Jabiru 2200? Just a couple days ago I saw from www.compactradialengines.com an 85hp MZ-301 with about the best power-weight-cost ratio numbers I have seen? Anybody know about or care to comment on this engine (and the company?)
Any help, ideas, comments, will be welcome and greatly appreciated. Also if anyone within a100 miles or so of Grundy VA (southwestern VA) has a Kitfox (tri-gear or tail dgr) I would like a close up look at it. Thanks again! Ernie
Ernest Deel
Rt 1 Box 349A
Vansant, VA 24656
276 859 0434
jdmcbean(at)kitfoxaircraf Guest
Posted: Tue Sep 18, 2007 7:22 am Post subject: New subscriber-1st post-request for info |
Ernie,
We can help.. please feel free to contact us off list.
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Ernest and Jane Deel
Sent: Monday, September 17, 2007 11:32 PM
Subject: New subscriber-1st post-request for info
Ernest Deel
Rt 1 Box 349A
Vansant, VA 24656
276 859 0434
[quote]<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The Kitfox-List Email Forum - --> http://www.matronics.com/Navigator?Kitfox-List - NEW MATRONICS WEB FORUMS - --> http://forums.matronics.com<![if !supportEmptyParas]> <![endif]>[b]
MichaelGibbs(at)cox.net Guest
Posted: Tue Sep 18, 2007 7:59 am Post subject: New subscriber-1st post-request for info |
Ernest sez:
| Quote: | I will want to convert to a tri-gear (nose wheel).
Are approved parts and plans available? From who and where? Is this
I think you are on your own as far as plans go, but the process isn't
rocket science. Some welding and reinforcement is required, but I
don't think the engine choice matters at this point unless you plan
to do something truly exotic.
You'll need a mounting plate welded to the tubing just behind the
firewall and you'll need to reinforce the tubing just behind the
seats. On mine, we did this by welding plates between the tubes, as
shown in the attached photos.
The nosewheel assembly was supplied by the factory and the main gear
is from Grove.
Hope this is helpful,
Mike G.
N728KF
Phoenix, AZ
158.73 KB |
534 Time(s) |
171.69 KB |
519 Time(s) |
190.63 KB |
553 Time(s) |
74.01 KB |
522 Time(s) |
Lynn Matteson
Posted: Tue Sep 18, 2007 8:00 pm Post subject: New subscriber-1st post-request for info |
Call me a relic, but I personally can't see why anyone would take a
perfectly good 'fox IV Speedster tailwheel plane and muck (sp?) it up
by going to a nosewheel! I think you need to ask yourself why you
want to convert....lack of tailwheel experience? Get trained. Is it
because the person who caused the wing-tip and gear damage blamed it
on the tailwheel? Maybe they needed training. Insurance writers don't
like/understand t'wheels? Might be something to that. Tailwheels have
been around since day one...well, maybe day two, but they are
learnable. Take it from a 70-yr old, who learned in a tailwheel
Kitfox...my own...at age 69.
As to your other decision...the engine....more and more people are
going to Jabiru...'nuf said.
Lynn Matteson
flying w/400+ hrs
On Sep 18, 2007, at 1:32 AM, Ernest and Jane Deel wrote:
| Quote: | From; Ernest Deel ernieandjane(at)naxs.net
Ernest Deel
Rt 1 Box 349A
Vansant, VA 24656
276 859 0434
http://www.matronics.com/Navigator?Kitfox-List_-
============================================================ _-
forums.matronics.com_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Tue Sep 18, 2007 11:41 pm Post subject: New subscriber-1st post-request for info |
Lynn sez:
| Quote: | ...I personally can't see why anyone would take a perfectly good
'fox IV Speedster tailwheel plane and muck (sp?) it up by going to a
nosewheel!
Let's not start the "why the heck would you want to do that?" stuff
again. The guy asked for advice on how to do something, not for a
bunch of editorials on something that is, after all, a personal
decision.
Mike G., Kitfox List Co-Moderator
N728KF
Phoenix, AZ
Lynn Matteson
Posted: Wed Sep 19, 2007 1:38 am Post subject: New subscriber-1st post-request for info |
You're right...I apologize...it was late at night and I should have
been sleeping...
Lynn
On Sep 19, 2007, at 3:41 AM, Michael Gibbs wrote:
<MichaelGibbs(at)cox.net>
Lynn sez:
> a nosewheel!
decision.
N728KF
Phoenix, AZ
N369LM |
john(at)leptron.com Guest
Posted: Wed Sep 19, 2007 6:13 am Post subject: New subscriber-1st post-request for info |
Mike G,
The main gear bracket you show does not look stock, who cut that out for
you? We need something like that for our model 1.
John Oakley
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Wed Sep 19, 2007 7:49 am Post subject: Re: New subscriber-1st post-request for info |
| Quote: | | Will this be considered a major airframe modification? and what kind of "paper-work" and inspections will be required? |
Ernie,
If this airplane already has an experimental airworthyness certificate the answer is in the operating limitations issued with it. Some say you need to notify the FSDO in writing about the modification. Some say just put it back into Phase one (test phase) for five hours, I think, and make a log book entry.
It seems like every FSDO interprets the regulations differently so a call to your FSDO will probably be needed to be sure.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Guy Buchanan
Posted: Wed Sep 19, 2007 10:46 am Post subject: New subscriber-1st post-request for info |
At 10:32 PM 9/17/2007, you wrote:
| Quote: | | Engines?? Possibly a Jabiru 2200? Just a couple days ago I saw from www.compactradialengines.com an 85hp MZ-301 with about the best power-weight-cost ratio numbers I have seen? Anybody know about or care to comment on this engine (and the company?) |
Welcome Ernie! It sounds like a fun project on your hands. I had never seen the engines you referenced so I'm glad you showed them. They look great, but of course are two-stroke, with all the attendant problems, which are:
1. Mixing fuel. Two strokes require oil in their fuel. Rotax uses a convenient oil pump to inject oil into the intake manifolds precluding pre-mix. If these don't have oil injection you'll have to pre-mix. It's not a big deal at home, but I suspect it would be a real pain on the road. (I do a fair amount of long cross countries and it's still a pain for me as I have to carry up to 20 pints, (almost 20 pounds,) of oil with me for a week of flying.)
2. Fuel use. Two strokes are notorious gas hogs. You'll want to check on that for these engines.
3. Noise. Two strokes are notoriously noisy, with a high pitched whine that can be annoying.
I sound disparaging, but please note that I'm running a Rotax 582 and have been quite happy with it. I can't help you with the trike conversion but there are plenty that have done it. If you don't get a response here email me privately and I'll try to hook you up with a couple.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Posted: Wed Sep 19, 2007 11:30 pm Post subject: New subscriber-1st post-request for info |
John asks:
| Quote: | The main gear bracket you show does not look stock, who cut that out
for you? We need something like that for our model 1.
I'm pretty sure that is stock Grove mounting hardware, John.
Mike G.
N728KF
Phoenix, AZ
