jdmcbean(at)kitfoxaircraf Guest
Posted: Fri Sep 14, 2007 2:15 pm Post subject: 406 ELT's |
We have been looking into this for sometime and finally got an answer
back... We are an OEM for Artex 406 mhz ELT's. There is a model now that
is a replacement for the AK-450 and the ACK models. Unfortunately the
remote switch in the panel is a little different so it will require a slight
mod to the opening for the remote switch.
As reported the response time is significantly better then the current
system. Fact is Doppler positioning allows the 121.5 signal tracked to
within approx 12 mile radius and the 406 signal in within 2 mile radius..
the new system also sends owner data to the satellite so searchers know who,
what and where.. I believe it also sends contact information.
Here is the bad news.. the current retail is $1148.00 plus S&H. This does
include everything needed.
Attached is the brochure.
Give us a shout if you're looking to upgrade or install the 406 system.
Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
8:59 AM
560-6610_Specification.pdf |
279.36 KB |
1584 Time(s) |
