CJ vent filters
kelmonroe(at)comcast.net
PostPosted: Thu Feb 16, 2006 4:41 pm    Post subject: CJ vent filters Reply with quote
I am looking for filters for my 285hp CJs case vents. Or should they be left open?  Thanks Kelley
cpayne(at)joimail.com
PostPosted: Thu Feb 16, 2006 5:31 pm    Post subject: CJ vent filters Reply with quote
Kelley,
Thanks Kelley
Up there in the Land 'o Lakes where the Mosquito is the State Bird, I'd prefer to keep those vents covered. Fine Scotch pad will work with tie wraps, keeps the critters and dirt out and *some* of the oil in, especially when inverted. If you plumb the oil tank vent to the "Y" crankcase vent, only the gearbox vent needs covering. However, don't fly into icing as the vent filter freezes over, pressurizing the crankcase and blowing all the oil out somewhere.
Craig Payne
dave(at)davelaird.com
PostPosted: Fri Feb 17, 2006 1:40 pm    Post subject: CJ vent filters Reply with quote
Hi Kelley,
This is what I use on my nose case breather vent on my 285HP Housai.
http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?
lang=-1&catalogId=10002&storeId=10001&categoryId=13323&searchItemId=1370
It's a K&N filter, I change it out every annual. $17.99
Keeps the engine and fuselage cleaner, especially If you do any
inverted stuff.
Dave Laird
N63536 1983 CJ6A "Betty"
Dallas
