Arran.Addington(at)state. Guest
Posted: Thu Sep 13, 2007 10:15 am Post subject: Looking for a spray paint rig solution |
Hello Everyone,
Probably by the spring I should be ready to start spraying on the polybrush, polyspray, and polytone, onto my MkIIIc. My question to the group is what kind of spray rig should I buy? About the least expensive rig is the Campbell Hausfeld HV2500 High Pressure, Low Volume unit at about $300, and it goes up steeply from there. I don't have any experience painting beyond rattle can spray paint. Besides painting the airplane, and the occasional hobby project, this is not something I will be using on a regular basis, so I don't feel that I can justify spending a ton of money on a commercial rig.
I want a decent quality finish, but am not interested in entering it into Airventure for competition. I understand that this is a fairly subjective subject, but I would like to see what the wisdom of the group is.
I appreciate your help.
Arran J. Addington
Transportation Planner
Office of Local Programs
Suite 600, James K. Polk Building
505 Deaderick Street
Nashville, TN 37243-0341
voice: 615-253-8526
fax: 615-741-9673
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Thu Sep 13, 2007 11:25 am Post subject: Re: Looking for a spray paint rig solution |
I was in the same boat as you.
I bought a 115v electric 2.5HP compressor with a 8 cu ft tank that does 6 CFM at 50psi from HarborFreight for $189.
I also suggest buying 3 spray gun and or paint tanks 1 each for the PolyBrush, PolySpray and PolyTone.
I bought 3 of the Pint sized guns for ~$9 each and one of the Quart sized guns for larger areas ~$29.
Add some latex gloves, a good cartridge mask, quick connect fittings for the guns, a water/air filter trap and I have a good spray system that does a great job for around ~$300.
You should get 3 quart sized guns.
You also need to practice with the complete PolyFiber system for one patch at least to get your guns adjusted right.
My first patch worked but is fairly ugly since you cant sand the PolyBrush and I applied the PolyTack without smoothing it with the iron properly. Solid but not pretty.
The next patches I have done are works of art...but it really took one time to realize what was important in the application.
PS: Watch out for the products from Harbor Freight, most of the products comes from China and my friend got a free live black 2" scorpion with his tool belt. He didn't even need a coupon to get that bonus...
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
1planeguy(at)kilocharlie. Guest
Posted: Thu Sep 13, 2007 12:20 pm Post subject: Looking for a spray paint rig solution |
Hello Everyone,
is.
Arran J. Addington
voice: 615-253-8526
fax: 615-741-9673
<snip>
I'll throw my $.02 worth here...
Find someone who has experience as a sprayer...it is a skill like any
other that requires a little practice to get right. Most guys I know
that can do it have experience messing around with hot-rods or something
and in that experience came plenty of sanding it off and trying again.
That being said...it is a lot more work to sand down a bad spray job on
an airplane and the extra coats to try and get it right get heavy and
expensive. I don't consider an airplane project a good place to "learn"
how to spray.
Second point here...you can build the most perfect Kolb ever built,
accurate in every way down to the nearest thousandth then put the best
fabric job ever put on an airplane as well...if you put a crappy coat of
paint on it people will always give it a slant-eye kind of look , like
"You actually fly in that thing?". I know from whence I speak.
The money you would spend on the equipment and calling in a couple of
favors might get you a good looking paint job. Ask around the EAA
chapters or the local ultralight strips...
Also you will have to build a good place to spray if you want a good
finish...yes I know people who have sprayed outside or in make-shift
booths and get away with it, but IMHO it is the exception not the rule.
A good spray booth with proper lighting and ventilation makes all the
difference in the world.
THAT BEING SAID...if your willing to waste a little paint and time on
some practice pieces or maybe repaint the old clunker car for a practice
job you could learn a new skill...some people pick it up quick and paint
like DaVinci !!!
Jeremy
MKIIIX040
Joined: 31 Mar 2006 Posts: 123 Location: Millinocket, Maine
Posted: Thu Sep 13, 2007 4:00 pm Post subject: Looking for a spray paint rig solution |
A friend offered the use of his, I wouldn't paint an outhouse with one. Get
a good quality siphon gun (bottom feeder) with a wide spray patern. HVLP
clones dry up while your using them. You must clean after each use even of
the same product so why clean more than one?
A small touchup gun is the only extra you might want.
Dust and dirt will find poly brush no matter what. I think it even came
from other towns just to peev me off. It must be static. You'll feel that
when you wash your sufaces.I often wondered if grounding would help, never
tried it.
I ironed the dust flat with a teflon sheet, go ahead laugh, it worked.
I practiced on the bottom sides. They came out perfect.
Then turned them over and proceeded screw up the part that showed.
Vic
Maine
_________________ MKIIIX040
912UL |
Wade Lawicki
Joined: 27 May 2007 Posts: 31 Location: Nashville Tn.
Posted: Thu Sep 13, 2007 5:45 pm Post subject: Re: Looking for a spray paint rig solution |
Arran,
I live in Lebanon and I`m going to be spraying a wing this weekend, buy my stuff at Harbor Freight and works fine after a little practice id love to come see yours.
Wade
